Slugish
![]() Join Date: Jan 2005
will this work
have a 84 1/2 ton with the huge fuel guage & idiot lights. Have found a tach /fuel combination guage. will this work on my truck? Seller says it fits 73- 86 model years. Am a little leary if it will work or not . Anybody?
Wishin' I had more money!
Re: will this work
I don't see why it wouldn't?
All I can see being new is that you'll have to run new wiring for your tach... Someone correct me if I'm wrong. |
Re: will this work
1976 Chevy 1/2T 2wd SWB ![]() ![]() 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com ![]() Last edited by dooce; 06-11-2008 at 11:39 PM. |
#4 | |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: will this work
HOWEVER, IF you're swapping from idiot lights to gauges for the oil pressure and temp gauges, you will need to swap out the sending units for each as well. Also make sure you have a VOLTAGE GAUGE for the idiot battery light and not an amp gauge as it requires a shunt inline somewheres for it to work properly. I answered these questions for another member in the "ELECTRICAL" section this past weekend. Here is a link to it. http://67-72chevytrucks.com/vboard/s...d.php?t=294860 By the way, if you want to have some REAL FUN try doing what I did to my cluster!!! That was a real chore. Link in sig below.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
