Old 06-11-2008, 09:40 PM   #1
wdsteeves
Question Camaro rearend for a 58 ?
Anybody using mid 90's Camaro rearends for there trucks. Got a chance to pickup a 95-96 IROC for $100 bucks complete good assembly. Is it close to the right width? Any info would be appreciated.Thanks
wdsteeves is offline   Reply With Quote
Old 06-12-2008, 09:08 AM   #2
xakk
xakk's Avatar
Re: Camaro rearend for a 58 ?
A friend gave me the rear out of what I think is a 98 Camaro that I was going to try using in my 57, but it's too wide. My original measures 62" from mounting surface to mounting surface and the Camaro one measures something more like 65". I think the 3rd gen f-body rears were narrower. However, I'm pretty sure the disc brakes from the 4th gen rearend can be bolted right on to practically any other 10 bolt rear, so it might still be worth it.
xakk is offline   Reply With Quote
Old 06-12-2008, 10:22 AM   #3
1-ton of fun
polishing a turd
1-ton of fun's Avatar
the brakes can be swapped. you just need to find some big front ones to match...
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 06-12-2008, 12:28 PM   #4
Daniel U
Daniel U's Avatar
82-92 Camaro/Firebird(F-body) will fit without modifications. I have an '87 10 bolt rear with disc and posi in my '54. My mom has an '89 Firebird Borg Warner 9bolt like the one in my '88 IROC in her '54. BTW, I believe that '89 was the last year of the IROC---->http://www.thirdgen.org/1990-chevy-camaro
Just a little 3rdGen trivia. The 4th gen rear is wider. Not sure how much, but it is wider. You may be able to change the offset of your wheel to make it work, not sure though? Also not sure if the rear width changed in the AD trucks (47-55)to TF trucks(55-59).
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
