06-12-2008, 01:43 AM | #1 |
Media Blasting Body - Worht the money?
While I have everything torn apart on my 62 frame off - I got some quotes for media blasting the body. I can have all the sheet-metal done for 750 front to back, which seems like a fair price but the question is it really worth it to blast to bare metal?
What is the benefit - if any - to blasting over sanding (other than time i guess)? The guy will be doing some sort of media blast if I go with it, and he has lots of experience so I am not worried about warped metal or adverse reactions to primer. I am working with a decent but not intense budget for the frame off - so if it is simply a matter or time spent to sand then I will just have to stock up on bud light and hit it hard for a few weeks I guess, but if it makes a big difference in showing then it might be worth it in the long-run. Thanks in advance guys Kurt Last edited by 83burban; 06-12-2008 at 01:43 AM. |
06-12-2008, 06:50 AM | #2 |
Re: Media Blasting Body - Worht the money?
I think the biggest advantage is time savings and blasting can get intio areas you can't reach with sandpaper or a wire brush. I do think it is very beneficial to strip to bare metal to get rid of so much paint build-up and to uncover what work previous owners may have done incorrectly. I stripped my 66 by hand as much as possible. Takes a TON of time to do it this way, but I don't have the $750 to have it done. My time is free. I used some checmical strippers and it works fairly well, but I've found a 80 grit paper on a DA workd much better than expected, and I use a wire cup on a 4 1/2" grinder to get to other areas where the DA has trouble without tearing the paper. Could always use a Harbor Freight $69 sand blaster to get into the last of the areas yourself to finish the job if you wanted.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 |
06-12-2008, 08:03 AM | #3 |
1961 crewcab
A friend of mine with a body shop chemical strips all the sheet metal, then he blasts the jambbs, and crevices... he says with all the compound curves, and bends you don't have to worry about warping the jambs.
I worked on a 57 chrysler that had been acid dipped, it was dreamy... all that fresh brand new looking metal. |
06-12-2008, 08:26 AM | #4 |
Tot Roddin'
Media blasting is a great step, because it will save you time and a lot of extra effort on your part, with a quicker result. One thing that you have to watch with sandblasting is that it builds up heat which then causes warpage. I just had my SWB (bed only) quoted, and granted there's not a lot of place in the area that offer this service, but the quote was $400 for only the bed. $750 for all the sheet metal front to back is a steal!!!
As far as the frame, I would just have it sandblasted because the metal is a lot thicker and won't warp on you. Good luck, and be sure to post some pics!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
06-12-2008, 08:27 AM | #5 |
Tot Roddin'
Acid dip is another thing to consider, but that is a lot more $$$$$.
06-12-2008, 10:13 AM | #6 |
We just had this 68 vette media blaster for $650. With us it boils down to saving time and money. this Vette had been painted three differant colors. It sure makes the body work go easier,
The last picture is what you look like when you are done Last edited by mbgmike; 06-12-2008 at 10:15 AM. Reason: spelling |
06-12-2008, 10:19 AM | #7 |
Lee and I had his frame sand-blasted, primed and painted with epoxy black for less than $400.00 and all of the sheet metal, including many of the small interior parts media-blasted and primed for around $1,400.00, so I think $750.00 sounds like a good deal.
One thing I would caution you about is making sure you have all of your parts accounted for when they go to the media blaster. It is frustrating when you forget to include something that you wanted blasted, but forgot it was on a shelf somewhere. I also suggest visiting the media blaster during the process, to ensure all areas are done and all media removed, prior to shooting primer. If not, the grit will end up in the primer and you will have a lot of hand work to do. The other reason I like to have all sheet metal stripped, is to ensure the actual condition. Sometimes a glaze coat of filler will hide a small dent, crease, hole or premature rust and this will expose all of these imperfections. Although some consider their time to be free, however with family, work, life and only 24 hours in a day, your time is worth something, not to mention the sand paper, stripper etc., to do it yourself. In closing, making repairs and shooting primer over pristine metal is more efficient and effective over the long haul than trying to work with years of wear, rust and road build-up. |
06-12-2008, 12:57 PM | #8 |
I asked about two bedsides and they wanted $350 a few years ago... I did sand blast my frame and other parts myself and all turned out well. Need a good compressor for that though.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
06-12-2008, 01:08 PM | #9 |
For anyone interested, the shop that is doing the work is Blasting Specialties and Powder Coating. http://www.blastingspecialtiesandpow...g.com/home.htm
They will be powder-coating frame, all suspension parts, and axle housing for 575. Seem like a fair place to work with and I will give a full report on the quality of their work in my build thread for anyone interested in having work done in So-Cal. I am trying to stick with-in a budget, but the general concesnsus(sp?) seems to be that while its down and apart, it would be worth the expense. I have until the first week of September to complete the truck before school (everything except motor and transmission) so maybe I'll build it complete without a driveline and when I come back for Christmas break build up the motor and trans and drop them in. Tony, I have everything in crates, seperated by what goes were. one for chrome, one for blasting and powder coating, another for just blasting, etc; but good tip anyways. Thanks for the help, Kurt |
06-12-2008, 02:10 PM | #10 |
Yes, blast it!, you just don't know whats lurking under there.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
06-12-2008, 02:58 PM | #11 | |
Tot Roddin'
06-12-2008, 03:31 PM | #12 |
One day...
ya i bought a handheld speed blaster from matco for $50 and 4 bags of sand it worked really good. It took me a whole day to do my whole cab but for a hundred bucks it wasn't that bad.
06-12-2008, 03:43 PM | #13 |
any problems with rust if you media blast all the body parts and immediately put a primer back on? I was thinking of doing this and someone told me if I let the panels sit for too long before body work and paint, that rust will eventually resurface? A reputable body and paint man told me if I media blast myself and later brought the truck to him he would just have to do it over again. It does not make sense to me.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
06-12-2008, 04:08 PM | #14 |
I plan on getting panels blasted in a series - starting with the cab. I will address whatever issues there are to address with a welder and then primer all the metal. I expect no more than a day of work and it will all be in the sun, so no rust issues popping up later.
06-12-2008, 07:43 PM | #15 | |
One day...
06-12-2008, 07:56 PM | #16 |
What primer do you guys recommend? Any particular brand or company? Looks like I'm going to have to buy a spray gun now
06-13-2008, 12:04 AM | #17 | |
60-66 Nut
One brand that I've been using lately as well as numerous reputable local body guys, is a brand called Northstar. They make real good products and at a reasonable price, but I don't know if it is available in your area. Also IMO media blasting is the best way to go, that way you don't have anything hidden that may show up later. I don't think you'll have any regrets as long as the blaster knows what they're doing.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 06-13-2008 at 12:07 AM. |
06-13-2008, 12:18 AM | #18 | |
KOFFIN DRAGGER
06-13-2008, 12:35 AM | #19 |
Thanks for the info captainfab.
How are Eastwood products? How realistic is it for me to expect a good paint job for a first timer? I have alot of experience with rattle cans and have used a paint gun a couple times. I would like to give it a shot, just want to make sure that I do my best possible work. Thanks alot |
06-13-2008, 12:39 AM | #20 |
60-66 Nut
Glad you mentioned that Derric....I almost forgot about the PPG NCP primers that I believe is a etching epoxy primer....I've used this one also. IIRC the NCP primers don't have the isocyanides (sp?) Although it is my understanding that if the metal is media blasted use of an etching primer isn't as crucial since the media blasting etches the metal. Any opinions on that?
06-13-2008, 12:57 AM | #21 |
65 - Chevy C10
There is this relatively new stuff from SEM called Metalock .
I wish I would have bought this stuff! Its a high build epoxy primer. You dont get this high build from normal epoxy primers so you are essentially able to eliminate the use of an extra high build primer. All in one if you will! Two popular techniques are epoxy primer or etching primer. If you do not do one or the other you will rust up in no time and the work WILL be done for nothing. Trust me. You will want to get it protected ASAP. |
06-13-2008, 01:01 AM | #22 | |
65 - Chevy C10
06-13-2008, 01:08 AM | #23 |
I had my 70 rs z28 done, if you want great final results that is the way to go, Remember to let the body guy know that you had it done so he can prep it correctly, or you WILL have bad adhesion problems. I see a GTO that an inexperienced body shop did, the paint game off in sheets do to bad prep after the soda blast process. ish.............also, wash out the vents and hard to reach areas...it gets into everything. I will do it on this next project (1959 austin healey 100-6) for sure.
06-13-2008, 07:17 AM | #24 |
Rust Buster
An etch primer is a good idea. I do some of my own blasting, and more recently have had one soda blasted, and liked the results so much, I will be investing in a soda blast system so as to have the ability to do either. The downside to the sand or media is the never ending sand and media that shows up afterward. Soda blasting can be washed down, and it dissolves. If left on, it will act as a natural rust inhibitor for up to 6 months without having to prime. I will post pics later when I get the system in. I am doing a few more mods to the shop before I make this investment. Jerry
06-13-2008, 11:26 AM | #25 |
65 - Chevy C10
And as for the process being worth the money... well that all depends on how much time you have. Its been 2 years and I just finished sanding my last panel down!
