Old 06-12-2008, 11:48 AM   #1
Googenheimer
Turn Signal Replacement
Over the weekend my turn signal broke inside the column. The actual lever is still intact, instead it was a little piece of plastic that broke and fell out of the column. I'm not sure what it was. Now the lever moves up and down quite freely and if I try to signal to the left or right it doesn't turn on the signal, but instead honks the horn!! Anyone had this happen before and where would be the best place to find a replacement?
Googenheimer is offline   Reply With Quote
Old 06-12-2008, 12:10 PM   #2
mekdad
mekdad's Avatar
Re: Turn Signal Replacement
I found new parts for mine at the local car quest.Mine was the switch in the colem and I had to take it all apart.
you never know what you can do until you have to undo something you have done!
mekdad is offline   Reply With Quote
Old 06-12-2008, 12:23 PM   #3
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Happens all the time in a 40+ year old truck. The reason the horn is honking is because a now mis-aligned metal part of your busted t.s. switch is grounding out against the horn pin in your column at certain wheel positions.
Pull your steering wheel and schlock in a new switch from Wes @ Classic Heartbeart (they're like 28 bucks + the ride). It'll take ya' about an hour and you'll be good to go for another 40 yrs.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 06-12-2008, 01:15 PM   #4
Googenheimer
I noticed that my local AutoZone has the turn signal switch, however the plug looks way too modern for a '67 truck. I also noticed that LMC truck sells the switch with the adapter. I'm tempted to get it at AutoZone because I could do it now and avoid a driver's side window side chat with my friendly neighborhood officer. However I'm wondering if my instincts are right and I'll need a special adapter to make it fit? Is this correct?
Old 06-12-2008, 01:46 PM   #5
mahanian
C10 addict
mahanian's Avatar
The turn signal switch from autozone will have the newer style flat harness and may or may not come with the half moon harness adapter. Best bet is to swing by Autozone and take a look at it.
Jared
67 C10 CST Short Fleet Big Window
65 C10 Custom Short Fleet Big Window
67 Camaro RS
mahanian is offline   Reply With Quote
Old 06-23-2008, 03:11 PM   #6
Googenheimer
Thanks for the previous replies. I bought the unit at AutoZone ($27 or so) and it did include the half-moon shaped adapter with it. I installed it over the weekend and had mixed results. I now have Hazards, which I previously didn't realize had broken off, and they work great. But I turned on the turn signals and I heard erratic clicking, like it wanted to work but the signals turn didn't come on. I went to pull out the relay to check it and YOWWEEE, it was cooking!! I bought a new relay to put back in but my question is do they normally get real hot when they go bad or does that signal that I have a short somewhere in the column? I'm not concerned about the $2.99 relay toasting again. I'm just worried that I'm also cooking something else at the same time.
Old 06-23-2008, 03:14 PM   #7
mekdad
mekdad's Avatar
I had pinched a wire when I put mine together and it did the same thing.
Old 06-23-2008, 03:39 PM   #8
mahanian
C10 addict
mahanian's Avatar
I agree, sounds like you are grounding a live wire somewhere
Jared
67 Camaro RS
