Bagged the 68' - lower arm questions - 73+ swap, modifying arms
Like many others it seems my front bags rub the lower arms after cutting the SD cups. No matter the reasons I am looking at getting another set of lower arms (either stock or 73+) to cut the stock "pocket" and weld in some tubing. This will stop the rubbing and get a little more drop since the rear is lower than the front.
I have done some searching and have learned that the 73+ arms will work, but am still confused about the exact details (ball joints, different bushings etc). I am running stock spindles and drums, and only want to change lower arms, nothing else. So far I have found the threads below to be the most helpful cutting arms... http://67-72chevytrucks.com/vboard/s...t=control+arms more cutting arms... http://67-72chevytrucks.com/vboard/s...t=control+arms 73+ arms http://67-72chevytrucks.com/vboard/s...d.php?t=256925 &highlight=control+arms I have a line on some 73+ arms so considering getting those and modifying them. Any help would be GREATLY appreciated. pic of the truck ![]() |
Re: Bagged the 68' - lower arm questions - 73+ swap, modifying arms
balljoints are different
I have heard they are different but will work in the 68 spindles, is this correct?
Basically need to know what balljoints to use... |
Texas Big Wig
Here is my old thread, & if I am reading what you said correctly it should apply
http://67-72chevytrucks.com/vboard/s...d.php?t=251067 They should bolt on just fine, & if I remember correctly the upper BJs are the different ones... but dont hold me to it lol Last edited by Spray-Bomb; 06-13-2008 at 07:27 PM. |
Thanks for the link, I looked that over and I think I just need to get some arms and start cutting...
Ill post my escapades in this thread when I get the time to make the swap. |
