06-13-2008, 09:12 AM | #1 |
Damn Yankee
"Be Cool" questions
I'm trying to fit a "Be Cool" radiator into our project truck but I'm having issues using stock mounts. The lower 4 core saddles seem to work fine but neither the 3 core or 4 core upper brackets will work. Has anyone installed one of these and what did you use for mounts?
06-13-2008, 09:45 AM | #2 |
Re: "Be Cool" questions
I have used them before and had the same problem. There radiators are a little thicker for the 4 core mounts. I just trimmed and shaved the rubber mounts and it worked fine and you couldn't even notice
Ron
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
06-13-2008, 09:55 AM | #3 |
Damn Yankee
My issue is the height....the top mounts won't sit down on the core support
06-13-2008, 10:22 AM | #4 |
Trucks N Tranzams
I had a similar problem with my Griffin Radiator. I had to trim my core support and modify my upper brackets. It fits well now, but takes up all the available room for it. I also removed the steel supports from the bottom supports using only the rubber peices to support the bottom. The fan shroud keeps it securely in place
My truck stays cool even on the hottest of days.
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" Last edited by Arad68; 06-13-2008 at 10:24 AM. |
06-13-2008, 10:34 AM | #5 | |
Damn Yankee
06-13-2008, 12:19 PM | #6 |
18 Till I Die
I am watching this thread. I was going to order a new Be-Cool but I wanted it to fit "nice". Could you not machine some nice spacers to make the upper mounts fit nice on the rad support? Is the rubber inserts to thick?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
06-13-2008, 12:41 PM | #7 |
That's right, it's Copper!!
I had to trim the top mounts and the rubber spacers as well. If you were to build spacers to go under the top mounts the fan mounts would be way off!
06-13-2008, 01:54 PM | #8 |
Damn Yankee
06-13-2008, 01:57 PM | #9 |
Damn Yankee
It does look like spacers would work- IF you're using something other than the mount to mount your fan assembly. My fan assembly mounts with different brackets that hook over the top and bottom of the radiator....so I think I could get away with spacers. But a fan mount like the one above won't work with the spacer
06-13-2008, 02:03 PM | #10 |
Parts and more parts
I have a "Be Cool" radiator that I have fitted up to a 68 core support frame. I had to do a liittle changing to the lower mount to get the bracket to shift slightly sideways to form to the weld ribs. The upper brackets, did have a little height problem, but I made some billet aluminum upper supports that fit the core real well. These uppers had to have a little more material in them to raise their mounting point a little on the core support, so that they would align squarely with the core tanks. A factory set would need a little spacer help to get them to mount square. This can be done with aluminum "Mill" strap material fro a local hardware supply.
06-13-2008, 02:18 PM | #11 | |
Damn Yankee
06-13-2008, 06:23 PM | #12 |
Wow nelly..thats a sharp looking bracket...
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
06-13-2008, 07:38 PM | #13 |
My machine shop buddy gave me the first two for free, but I would have to ask him if he would make more and what his price would be.
06-13-2008, 09:34 PM | #14 |
Trucks N Tranzams
I'd be interested in a pair myself!!!
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
06-13-2008, 10:16 PM | #15 |
I'm also interested, looks like you started a trend....
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
06-13-2008, 11:10 PM | #16 |
Jon the mounts are in the box. The l-brackets bolt on the top and run across the core support and you drill them them into the core support and it holds the upper, they are in the box.
josh
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
06-14-2008, 07:19 AM | #17 |
Damn Yankee
06-14-2008, 09:50 AM | #18 |
Hello, You would have to cut the factory rubber mounts and use a universal mount from trans-dapt. This is what Stacey did on Trucks! - You would however have to fab some upper elec fan mounts though if you go that rout. *Billit upper mounts - count me in for a set.
06-14-2008, 08:59 PM | #19 | |
06-15-2008, 12:55 AM | #20 | |
Trucks N Tranzams
Can you post the website/email here?
06-15-2008, 08:56 AM | #21 |
Why yes I can. The gentleman that made these brackets has two CNC machines in a shop behind his house. He makes things for all different kinds of vehicles and street rods. He has a couple of different billet aluminum instrument panels and a billet glove box lid that he is working on for the 67-72 Chevy trucks. His name is Charlie Timmons and he lives not far from me, in Wichita, Kansas. He works his machining business as a second investment and does it in his spare time. His website is http://timmonsbillet.com/ . Take a look---I am not sure if he has the radiator brackets listed or not, but he and I have an understanding that I have no claim to the design, he can make them for his business. Call him and tell him what you are interested in and then tell him that Frank Seeney passed you on to him.
