Old 06-13-2008, 09:52 PM   #1
dammitmitchell
the pollock
dammitmitchell's Avatar
two choices
header wrap or short plugs which would be better?
this currently is the only burned plug boot,i have the summit wireseperators on their way to keep the wires away from the headers (they keep falling)
but the boot ..
im ticked.. i diddnt even think abou tthis when i put these wires on..
grrr.. its "one of those days"
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 06-13-2008, 10:52 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: two choices
I have champion short plugs, there real hard to find and there the price of regular plugs, I priced header plugs and there almost 40 dollars I'll take a picture of the clearence of the plug wire to header tommorrow and the header wrap won't be a bad idea to add
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 06-13-2008, 10:56 PM   #3
Square84
I don't think these pills work
Square84's Avatar
Re: two choices
i used a set of boot covers for $40
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 06-14-2008, 06:01 AM   #4
S10Fan
Old Heap Driver
Re: two choices
I'm using Taylor 409 wires with zero issues. Bought a universal wire set and routed them above the headers with some home made brackets. My plugs are standard Autolite #24.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 06-14-2008, 12:56 PM   #5
Pyrotechnic
Pyrotechnic's Avatar
Re: two choices
I had the worst time with those headers. The best solution I had was to get a short plug, dent the tube in very slightly, and cut up a coke can to make a heat shield around the boot.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 06-14-2008, 03:02 PM   #6
flamingbig10
6.0 powered square
Re: two choices
Aaron
Old 06-14-2008, 03:06 PM   #7
dammitmitchell
the pollock
Re: two choices
thank u all for the in put i greatly appreciate it.. im pretty upset with the headers right now, and now i kno wwhy my buddy hit his with a hammer a looong time ago... it's honestly a bit of a headache ya know...
i'll try the wrap first,
hey big 10 what is over your wires and where did you get it?
im not really up for an an entire roll of header wrap right now just want a woking temporary fix without spending aton of cash..
definatley gonna get shorty plugs
Army vet 02-08
Old 06-14-2008, 03:07 PM   #8
dammitmitchell
the pollock
Re: two choices
OHH!
a little birdy said i cant mix shorty plugs with long ones is that true? do i need to buy all new shortys"
is 1/2 an inch realy gonna make a difference?
Army vet 02-08
Old 06-14-2008, 03:14 PM   #9
flamingbig10
6.0 powered square
Re: two choices
I think its aspestace, a guy that used to build race cars gave it to me, I don't know where else you would find it maybe back in time lol
Aaron
Old 06-14-2008, 03:23 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: two choices
Don't use header wrap unless you want to replace your headerr frequently. It promotes rust through.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-14-2008, 05:32 PM   #11
slugish
Slugish
Re: two choices
Iused header wrap for my fuel line close to the engine block . No reason you couldnt use it for plug wires. Can buy a shorter -less expensive roll from summitt, just get some good cable ties to hold it on (like metal ,IKNOW PEP BOYS STOCK )
slugish is offline   Reply With Quote
Old 06-14-2008, 08:48 PM   #12
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Re: two choices
If your plugs are the same heat range, I don't think it should matter. I wouldn't do it, though.
I use Accel 276S and I had to dimple my 1 or 3 tube.
Then again, my heads use angle plugs so I was asking for it.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
