06-13-2008, 11:36 PM | #1 |
Removal of front bump-steering stop.. HOW?
Hey guys, another question... how have you guys removed the front bump/steering stop? I read to cut it off w/sawzal and then grind remains which is what i've done, but DAMN its a LOT of grinding... any other ideas???
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
06-14-2008, 12:13 AM | #2 |
Re: Removal of front bump-steering stop.. HOW?
it only takes like 5 min an arm. put the blade between the two pieces
06-14-2008, 12:31 AM | #3 |
A guy with a truck
Drill out the spot welds...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
06-14-2008, 07:19 AM | #4 |
what gringo said. Clean off the lip on the steering/bump stop. You will see a number of spot welds. Center punch the spot weld, drill it out, then take a hammer and chisel to between the arm and bump stop to pry it up. They come off real easy.
06-14-2008, 08:42 AM | #5 |
ah, everything was so gunked up i never saw the welds, will do that... thanks guys!
06-14-2008, 09:24 AM | #6 |
67-72 parts collector,…
Just a question,... I understand removing the "bumpstop",... but why remove the steering stop?
06-16-2008, 05:32 PM | #7 |
Hollister, CA.
That way your tires will rub on the shocks and frame.....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
