3/4 ton 8 lug rear axle
anyone know what this goes for and if anyone has any interest in it in the nw....?
Future TOTM Winner
Re: 3/4 ton 8 lug rear axle
Is it the older Dana 60 or is it a newer 14 bolt FF? What was it originaly removed from?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
![]() Join Date: Nov 2007
It may not be a 14FF. Could be a 14SF, if it came off of a 3/4 ton truck. A picture can help determine what it is and give a better idea on worth.
That being said, be careful with WIW posts, it may get locked because you're not a paying member. |
There is usually an interest if it is in good shape.
Priced vary a lot depending on model and gear ratios and if it is a posi or not. Some are considered way more desirable by some people than others are and the 4x guys are always looking for certain rear ends. If it has 3 something gears instead of 4 something it would probably be pretty desirable to someone right now. I'm looking for a Dana 60 with 3.55 gears for a leaf spring rear. One of the guys on another board had a nice Dana 60 for coil springs with 3.55's for 100.00 near Tacoma a while back that I thought was a good deal. |
