Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 06-14-2008, 05:26 PM   #1
truckdude239
truckdude239's Avatar
1988 S-10 blazer question for you guys
working ona 88 blazer at work (boss's truck) new motor and trans to get to the top trans bolts you hvae to raise the body up 3 inches well went to bolt the body back on today and the rear body mount on the passager side gott he bolt half way in the the nut broke loose in the body how to i fix this or let it ride?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-14-2008, 11:00 PM   #2
66skylarkpost
66skylarkpost's Avatar
Re: 1988 blazer question for you guys
really ??
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 06-15-2008, 08:48 AM   #3
truckdude239
yes according to shop key it was either lift the cab ad put a wood block under the mounts and serparte the trans ro drop the front diff and pull motor and trans together
David fuller
2000 Tahoe 5.3l 378
Old 06-15-2008, 12:57 PM   #4
kevinr1970
You must be working with an S10 style Blazer?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 06-15-2008, 04:03 PM   #5
truckdude239
yes s-10 blazer 2.8 with 700r4 4x4
David fuller
2000 Tahoe 5.3l 378
Old 06-15-2008, 05:16 PM   #6
66skylarkpost
uh huh i see ? lol
Old 06-22-2008, 08:58 AM   #7
truckdude239
Re: 1988 S-10 blazer question for you guys
ttt
David fuller
2000 Tahoe 5.3l 378
Old 06-22-2008, 06:13 PM   #8
BarryB
BarryB's Avatar
Have you looked to see if you can get to the top side of the nut area? You might have to remove some interior pieces, and see about either holding it with something or tack welding it back. Don't leave that will cause more problems down the road.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 06-22-2008, 06:51 PM   #9
54 jimmy
54 jimmy's Avatar
Thumbs up Re: 1988 S-10 blazer question for you guys
been there when i did the body lift on my 91 s10 extended cab 4x4. i tore part of the interior out then drilled an 1/8 hole from the underside and measured it. trandsfer that measurment to the inside floor. using a holesaw i opened the floor up got the nut reposioned welded it. last weld a the piece in that you cutout with the holesaw put the int back together. finished! it's time cousuming but it is the easiest way that i found to fix it.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 07-09-2008, 08:29 AM   #10
D13
D13's Avatar
When the eninge was out did you bend the firewall flange rearward so you can get them next time?
I found I could get at the top one from above for install (couldn't get on it direct enough to break it loose for take-out).
For the body bolt, we used to drill a small hole right next to the nut , just outside the socket on the bolt head. Then we would run a small bolt up there so when the nut spun it would jam against the bolt.
the better repair is the cut and weld above.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
