Old 06-14-2008, 08:34 PM   #1
tubbed55
tubbed55's Avatar
rear end height
I am ready to install my 4-link setup and was wondering was the minumum distance from the rear end to frame before needing a c-notch? Also anyone using a driveshaft loop. How far from the ground is the loop?
tubbed55 is offline   Reply With Quote
Old 06-15-2008, 07:31 AM   #2
Bob@ProAuto
Re: rear end height
I'd say that you need to find out what the coil-overs measure bottomed out and what ride height is. If bottomed out is 10" and ride height is 14", then you need 4" for the stroke plus 1" for extra added saftey.
Bob@ProAuto is offline   Reply With Quote
Old 06-16-2008, 06:21 PM   #3
tubbed55
tubbed55's Avatar
Re: rear end height
Can anyone post how far the top of their rear end tubes are to the frame at ride height on a four link setup for comparision. Thanks, Ronnie
Old 06-16-2008, 07:01 PM   #4
GRIMSS
GRIMSS's Avatar
Re: rear end height
Ride heights vary. Wheel and tire size vary. What truck you got?
When I get to building mine (56panel)the ride height will be around 5" so my tubes are going to be in the upper part of the frame. here's a drawing of the setup i'm working on.
You need to figure out your ride height and tire height.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
