Old 06-14-2008, 08:49 PM   #1
my67chevytruck
Under Construction
my67chevytruck's Avatar
Size of bolt
Can somone please tell me what size the bolt is on the trailing arm. I am planning on removing the 6-lug rear and replacing with a 5-lug rear.
Thanks..
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-14-2008, 08:55 PM   #2
70c10swb
no brain no headache
70c10swb's Avatar
Re: Size of bolt
Are you looking for u-bolt? Or TA to cross member?
1996 GMC Sierra z71
1970 SWB 2wd (project)
70c10swb is offline   Reply With Quote
Old 06-14-2008, 10:06 PM   #3
my67chevytruck
Under Construction
Re: Size of bolt
U bolt...
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-14-2008, 11:01 PM   #4
66skylarkpost
66skylarkpost's Avatar
Re: Size of bolt
5/8"
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 06-15-2008, 12:40 AM   #5
my67chevytruck
Under Construction
Re: Size of bolt
I will have to double check then. i think i tried all the wrenches i have and did not have one to fit to be able to remove the u-bolt from the trailing arm to remove the rear end. i will look again in the am.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-15-2008, 02:47 AM   #6
Kayotic
Kayotic's Avatar
Re: Size of bolt
The u-Bolt should 15/16", I believe the crossmember are 1 1/8".
Kayotic is offline   Reply With Quote
Old 06-15-2008, 07:58 AM   #7
caminokid
Chevy nut
caminokid's Avatar
Re: Size of bolt
Your right about the 1 1/8th. Just did two of them yesterday. Had to go buy a wrench and a socket cause I didnt have them.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 06-15-2008, 12:37 PM   #8
my67chevytruck
Under Construction
Re: Size of bolt
great thanks .. this is what i needed i will have to buy some wrenches as well.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-15-2008, 01:16 PM   #9
cdowns
cdowns's Avatar
Re: Size of bolt
the ubolts are 5/8 the nuts that go on the ubolts are usually 15/16
