Old 11-08-2002, 03:38 PM   #1
Charlie Peters
Leaf Spring backing plates 72 4x4 k-10
HELP,
I have a 72 chevy k10 4x4 which the backing plates holding the rear end which the ubolts tie into broke in half.... they rusted and broke in half! Keep in mind these u bolts go around the leaf springs and not around the rear axle housing like many newer trucks.
Question, where can I get a set of replacements or is there a newer style that will be a direct replacement. LMC and other chevy truck parts dealers don't show them.
I can be contacted at cpeters@learfield.com
Charlie Peters Owner of a 72 cheyenne C-20, a 72 cheyenne k-10 and my first car a 73 z-28 camaro.
Charlie Peters
Charlie Peters is offline   Reply With Quote
Old 11-08-2002, 03:51 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
If you want the new style www.offroaddesign.com sells a kit that convert our old style to the new style.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-08-2002, 07:34 PM   #3
meathead95
computer illiterate
meathead95's Avatar
I bought new ones at a place in decatur illinois, called decatur spring. They where 22.00 a piece I believe. I dont know their # you would have to call information. or any spring shop should have them
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 11-08-2002, 08:08 PM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
my buddy used some off of a dodge van. They were better than the original ones too.
Randy
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 11-08-2002, 08:16 PM   #5
Fast68Chevy
Fast68Chevy's Avatar
you talking about the cast iron retainer plates that sit underside of the axle tubes ? several ppl here are parting trucks that have these on them,
you could probably rob all parts off rear of a 73-up truck and convert to that style, the u bolts and steel plates that sit on top of the leaves
good luck
Fast68Chevy is offline   Reply With Quote
