Old 06-15-2008, 05:44 PM   #1
dooce
Somebody please help me decide!
So I have decided to lower my truck 4/6. After doing a lot of researching and searching for the right parts, I decided that I will be using 2.5" drop spindles, 1.5" drop springs for the front and 4" drop leaves with a 2" shackle/hanger out back, all from western chassis. I decided this knowing I could only seem to find drop leaves from two places, western chassis and performanceonline.com. Today I was on brotherstrucks.com was looking thru their suspension section and found two different types of drop leaves for my truck. one is the regular multi-leaf pack drop leaf and the other is a mono-leaf type. My first question is which multi-leaf pack do you think would be better? And then, what would be the pros and cons of the mono-leaf set up. It claims to meet or exceed multi-leaf specs. I assume they are talking about spring rate? It also has "fixed end" bushings. Please lmk what you think, thanks DOOCE
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 06-15-2008, 06:24 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Somebody please help me decide!
Any certain reason you want new springs? A flip kit is much cheaper.
Keith
Convert to disc brakes.
Old 06-15-2008, 07:41 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Mono leaf is just one big leaf!! Weigh capacity is really minimized. Go for the multileaf springs. The leafs are arched to achieve height and weight carrying retention.
I have a set of lowered leafs. Four leafs per side. Install coming soon.
My truck is 4/6 with 2.5 spindal & 1.5 coils. Hanger and shackel combo on the rear. 255/60/R15 tires. Measuring from the ground to the center of wheel well, 27.5-28" on three corners. One corner is nearly 29". It drives me nuts.
Measure first, then decide which drop you want and how to achieve it. I want one more 1" all the way around!!
gchemist is offline   Reply With Quote
Old 06-15-2008, 07:49 PM   #4
SCOTI
SCOTI's Avatar
x2.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-16-2008, 03:02 AM   #5
dooce
The PO removed a leaf or two out of the original pack to level the truck out. So If i just installed a flip kit, it would be much lower than I want the rear to be. I could go to the junk yard, buy a set of used springs and then install a flip kit, but I would rather not. New leaves seems like the better option for what I plan to do with the truck. That and I have really been a big fan of the flip kits.
Old 06-16-2008, 03:06 AM   #6
dooce
From what I've read and that you've said, it looks like I need to stay away from mono leafs. So which company do I go with for the multi pack? Anybody have feedback for any of them?
Old 06-16-2008, 02:46 PM   #7
dooce
well decided to go with the Western Chassis setup and some belltech street performance shocks all around. just ordered everything a little bit ago. will be posting pics in a few weeks.
