I am a bit of a cheap SOB when it comes to gas so perhaps some of you might want to consider some of my tried and true methods of squeezing the last drop out of a gallon of gas.
1--Hit your right foot with a big hammer ---it will become sensative and you wouldn't want to push very hard on the gas pedal! 2--Get rid of them dam big tires---the bigger, the more difficult it is to get them to roll. Stock is a 235X75R15. Anything bigger will hurt your mileage. You could go a bit narrower and get a little benefit but I like the breaking of the stock size. 3--Inflate the tires to 2-3 lbs above the truck mafg recommended pressure. Ie if it's 30lbs---run them at 33. You will get a little less resistance to rolling. 4-- Tune it up---new plugs, wires, points, condenser, fuel filter, air filter. If your carb has been used for several years, consider having it rebuilt by a good carb rebuilder. Ask them to set it lean. You could get 3-5mpg improvement from a good tuneup and carb rebuild!! 5--When you think that duals, headers, edelbrock intake, etc is helping your HP--maybe but it is hurting your mpg. Trust me, the stock intake has smaller primary carb holes that work like a NASCAR restrictor plate. You still have the low end torque but you save some MPG. Headers help in high rpm which you RARELY get into or need. The stock Rams Horns are decent flow tubes. 6--If you are running 373--411--456 rear gears---why are you burning the gas without the benefit?? If you tow a lot, 373 is adequate for 90% of towing needs. So, how many hours a month do you tow a heavy load??? 7--Most of the transmissions we have are 3-4 speeds with a 1-to-1 final gear. An overdrive will cut your final gear by 20% which will give you mpg!! 8--Don't waste money on aftermarket MPG devices, addatives, etc. They have all proved to be crap! 9-- If you run with an open bed, get a bed cover. That alone saved me 1-2mpg over 2 years of testing at highway speeds. 10-- Don't waste money on premium gas. Your truck will run fine on regular if you tune it accordingly. If not, you have too much cam shaft for street use. 11-- Run highway at 65 rather then 75. I loose 1-2 mpg when I run over 70. 12--SEE NUMBER 1 AND START AGAIN. HUCK |
![]() Join Date: Aug 2003
Re: How to improve you mileage
Or, you can do like Mr. Ignorant here. Drive a CRX everyday and look at the trucks parked in the yard everytime you come and go.
Fix It Till It's Broke
that's some good advice...thanks man...anyone else got any pointers?
Tony Black Beauty: 85 C-10 SOLD! Great White: 69 LWB Custom Camper/20 SOLD! Blue Dragon: 72 K-10 SOLD! The Tank 77 K-10 KIA panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for. I Made The Official So Cal Board Meet |
high-Tech Red Neck
Actually there is one problem I see with your list of things there. A stock intake manifold is made of Cast Iron. Cast Iron holds heat in, a hot manifold has adverse effects on the way that fuel atomizes, thus it can cause your truck to detune as it heats up. A good aluminum intake manifold that is not too radical is the way to go.
Keeping your truck in tune will do wonders as well. There is nothing like old plugs or bad wires to ruin your day here.
"He used to be a pretty nice feller, now he's a welder!" |
Truck and auto performance nut
...ride a bike. (m/c that is
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
I would keep the carb tuned to factory specs. Running a little lean might cause overheating or it will take out rod bearings due to spark knock. I also noticed when running lean I have to open the trottle blades more...
i just drive and put in more gas when needed
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
20' Daredevil (Ret)
![]() Join Date: May 2003
I finally caved in a couple weeks ago and have been driving the Jeep to work. Truck was getting low on fuel and the Jeep still had some... and it uses a lot less than the truck.
this is what i do but i got a big block so i dont even worry about it . but its not a daily driver
nickle and dime |
Rice Killing 101
well i got a big block with aluminum top end so get the weight of the small block... its a daily driver too
![]() o yea one more thing THINK SKINNY ![]()
![]() ![]() Ride: 1968 c20 lwb 327(orig motor)/np435/eaton 4.10 w/posi puttin in a 496 rebuilding trans need to rebuild diff :| need to start takin pics and start a project thread ![]() |
Tasty Cakes!
On the above note, stop picking up fat chicks. They really hurt your MPG!
![]() Srsly though, nice post.
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado Last edited by Riveted1; 06-16-2008 at 01:29 AM. |
Riveted with a user title like "Tasty Cakes" i would have expected you to be into that kind of thing
#13 |
Barrito Loco Diablo
I'm learning to not drive around unless i really have to, or even waiting until I have a list of places to run. I read that if you go to the farthest place you need to go first, then work your way back, somehow it's better on gas. I dunno though. I run a home made ram air on our 2002 Malibu with a 3.1 and when i'm on the highway, the gas mileage is amazing. I was thinking about running one of those dual intake air cleaners with dual intake tubes. That would have to increase a couple things.
I know those Tornado intake things work well on 4-cylinder motors, but not sure about 6 or 8 cylinders. I couldn't see how making a vortex out of the air couldn't help at least a little. What about carb spacers with vortex grooves? do those work? http://www.tornadofuel-saver.com/?gc...FRZjnAod3BxZVg There's a product made by BG. Called 44k. You add it to your gas tank like all those other worthless cleaners, but this one actually works if you have any sort of crap in your fuel system, or even if it's just been a year or so since a cleaning. I noticed a considerable difference after a tank or two of running. http://www.bgprod.com/home.html There's always higher flow air filters, like K&N. |
#14 | |
high-Tech Red Neck
#15 |
Tasty Cakes!
I think I just threw up in my mouth...
And semper, that title is an inside joke.... sry, u had to be there!
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
#16 |
changing over motor tranny and rear to synthetic lubricants helps as does the wheel bearings and properly operating brakes especially on drums those 40year old return springs are a good item to replace
lowered with an airdam limiting airflow under the vehicle has proven to help economy
#17 |
some people dont think of it, but LOWER YOUR TRUCKS
if its lower to the ground, the air doesn't move under neath the truck. an air dam can accomplish this also carrying around that big toolbox that never gets used, the 50 lbs of hay, and three sets of work boots dont help your mileage much.
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. Last edited by 69halfton; 06-16-2008 at 08:57 AM. |
#18 |
oh and i almost forgot, make sure you vacuum advance is working well, improper timing can KILL your milage.
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
#19 |
I always see people driving around with the tailgate down. I saw on mythbusters that it creates more drag to have the tailgate down than up. The best way they found was to install one of those black webbing tailgates. I know on my 97 if I run the canopy my mileage does worse about 1-2 mpg,
72' Custom10 4wd 350: Daily Driver |
#20 |
Actually my truck gets 2 to 3 more mpg with high test fuel then it does with regular.... Anybody else have the same results??
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
#21 |
![]() Join Date: Feb 2000
Good Post Huck!!
C10addict, I have wondered about this on my 99 Regal. With most stations charging only 10-15 cents more for the 89 oct. over 87 oct. fuel will the car get enough % increase in gas milage to pay for the difference? A 10 cent increase on $4.00 gas is only 2.5% increase in cost and if you can get lets say a 5 or 6% increase in MPG than it could be worth it. So if you are getting 12 MPG on 87 oct. fuel, you only need to get 12.3 or better MPG to pay for the difference of the 89 oct. fuel. However!! I sure that you can adjust timing and other things to inprove this some. On my 99 Regal (and other computer controlled engines) it would automaticly adjust the timing by itself. I have NOT tried this yet....just brainstorming with a couple guys about it.....What do you all think?? Any one try this? |
#22 |
Bigger tires have an overdrive effect on the freeway, but the best way to get better mileage is to park the truck.
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
#23 | |||
Barrito Loco Diablo
#24 |
Running higher octane gas may or may not help your gas mileage.
If you don't run high octane gas in a vehicle designed for it, you will probably see a decrease in fuel mileage; at least in newer computer controled vehicles. For instance, on my corvette, it will reduce the timing to compensate for lower octane fuel. I've heard on the 3.8L supercharged engines (Grand Prix GTP, etc) it really hurts thier mileage. Now for our old trucks, it's going to depend on your engine and how it is tuned. If it's a 350 running 10.5:1, then you should probably be running premium. If it's 8.0:1, you're pretty much wasting money on premium. You can also put some less restrictive mufflers on to pick up some mileage. More extreme: Remove the mirrors (reduce weight, improve aerodynamics). If you can't get a bed cover, remove the tailgate. Get rid of the big speakers and other crap. Weight is the enemy here. I completely agree with the brakes and wheel bearings mentioned above. Also, don't over look the parking brake, make sure it disengages too. |
#25 |
buy a bike for your daily driver, i got an old LTD 550 for $750 and it gets 55 mpg and it's almost as fun to ride as my truck is to drive and it's shaft drive so it kinda sounds like it has a blower like the truck, it's a win win situation
ΜΟΛΩΝ ΛΑΒΕ |
