Old 06-15-2008, 09:07 PM   #1
Skirtchaser
Skirtchaser's Avatar
Hard line water hoses
Greetings all, I'm probably crazy, but as usual, I got an idea..... Has anybody used hard pipe to make up radiator feed/draw lines? I keep thinking that I could have a local exhaust guy bend up some 1 1/2 aluminum pipe to closely match the stock hose bends then use a short piece of rubber hose at the inlet/outlet nipples to make the connections, like the lines on my Peterbilt. I think the polished aluminum would look very cool in the engine compartment, kinda like the lines on the old flat heads. I need a source for a straight up water neck on the manifold too (small block chevy) if anybody has any ideas, let me know what you think.
Thanks!
http://www.motherroadrods.com
Skirtchaser is offline   Reply With Quote
Old 06-16-2008, 12:26 AM   #2
originalJD
James
originalJD's Avatar
Re: Hard line water hoses
I had hard line water hoses when my 327 was in my truck. I did like haveing them in there. But I no longer have them as I switch to a 292 inline. I'm thinking of useing steel braided hoses now though.
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end.
http://viewmorepics.myspace.com/inde...lbumId=1709080
http://s258.photobucket.com/albums/h...e_top_view_all
originalJD is offline   Reply With Quote
Old 06-16-2008, 08:31 AM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
My 65 came with them, I think they are original...
I will post a pic later.
Old 06-16-2008, 01:02 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
I'm not sure if this is what you had in mind, but here's how I did radiator hoses for my '63 Chevy II...I will be doing the same thing for the '63 C-10
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-19-2008, 11:52 PM   #5
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
Theres also a guy here who makes radiator and heater hoses out of Pyrex.
Imperial Kustom is offline   Reply With Quote
Old 06-22-2008, 08:49 AM   #6
jonzcustomshop
1961 crewcab
Here is the upper on my 65, I think it is original, the lower is all rubber though.
Old 06-25-2008, 04:07 PM   #7
signguy
The upper hose on my 65 is just like Jonz so maybe it is stock for the 65
I thought of getting mine powder coated
signguy is offline   Reply With Quote
Old 06-25-2008, 06:28 PM   #8
joe231
joe231's Avatar
Hey Jon, I see you are also a member of the red ground cable brigade
but you don't have the heated ground option
CHEVY ONLY
Old 06-25-2008, 06:38 PM   #9
jonzcustomshop
1961 crewcab
yes that can be tricky if you are not careful!!!!
Old 06-25-2008, 06:42 PM   #10
283 Man
283 Man's Avatar
thats funny JoeI allways like funny stuff to laugh about even myself
283 Man is offline   Reply With Quote
