Old 06-15-2008, 09:33 PM   #1
Huskerboy2
Starter Problem Driving Me Crazy....Help
I've had a problem with the starter on my '68 1 ton. When I turn the key, the starter engages and then continues to engage, even after you turn the key off. I have to jump out and disconnect the battery to get it to stop.
So, I first changed out the ignition switch, since that was the easiest thing. I put in an NOS ignition switch and it did not fix the problem.
Next, I pulled the starter and had it tested. It bench tested fine at NAPA. I took it to a starter/alternator rebuild place and I went ahead and had them rebuild it. This company does all the work for the school district vehicles, etc. The guy was great. He let me come back there and he showed me how to rebuild the thing.
Anyway, I re-installed the rebuilt original starter, hooked up the battery, and the same %#@%$# problem. Starter wont disengage.
What do I do now????
I didn't think it would be a shimming issue, since I am using the original starter.
What about the actual ignition cylinder??? Could that be broken and not turning to the off position or something?
I would appreciate any help guys.
Thanks.
'72 Chevy Blazer
Huskerboy2 is offline   Reply With Quote
Old 06-15-2008, 09:35 PM   #2
Huskerboy2
Re: Starter Problem Driving Me Crazy....Help
By the way, the truck started and ran fine previously with no hint of this problem. After it sat for a few months, this problem just came up.
'72 Chevy Blazer
Old 06-15-2008, 10:17 PM   #3
El Jay
Gone to greener pastures
I would seriously look at the solenoid instead of the starter.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 06-15-2008, 10:45 PM   #4
Huskerboy2
The guy who rebuilt the starter put a new solenoid on it.
'72 Chevy Blazer
Old 06-15-2008, 11:20 PM   #5
N2GMTrux
N2GMTrux's Avatar
Some times when they rebuild the starters they ture the mounting pad location on the starter. This meaning they file it down to be flat and surfaced to mount flush. When they do this you lose about a thousands of an inch or more which causes the bendix or teeth on the starter to lock with the flywheel and keeps turning cuase it can't disengage. Need to go to your local auto parts store and get a starter shim kit from the HELP "MOTORMITE" section the red carton packs. Start with the thinest shim remove your silenoid and install the starter. Pull on the lever which engages the bendix and make sure the teeth engage and there is very little play. If you were to install the starter without the shim you would notice it is forced into the flywheel and there is no play,,,,,, but with a shim it will slide in with a little play and disengage freely.
Hope this helps..............
N2GMTrux is offline   Reply With Quote
Old 06-15-2008, 11:34 PM   #6
Huskerboy2
I guess it has to be a shimming issue. But, the surface wasn't altered when the starter was rebuilt. I was sure it would just bolt right up, since it was the original starter that had worked on there fine before.
What about the ignition cylinder???? Could that be sticking?
'72 Chevy Blazer
Old 06-15-2008, 11:34 PM   #7
463
463's Avatar
try this link to wire dia http://67-72chevytrucks.com/vboard/s...d.php?t=185665 http://67-72chevytrucks.com/vboard/s...d.php?t=193429
Trueman
463 is offline   Reply With Quote
Old 06-16-2008, 12:03 AM   #8
463
463's Avatar
(What about the ignition cylinder???? Could that be sticking?)
replace the switch. that is the next step. had the same problem on my 76 ton a few years back.
Trueman
Old 06-16-2008, 12:08 AM   #9
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
Try charging the Battery sounds like a low voltage problem to me . I have had them stay engaged because of a low battery many times . Worth a try . Bob
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 06-16-2008, 12:39 AM   #10
royo
royo's Avatar
x2
nickle and dime
royo is offline   Reply With Quote
Old 06-16-2008, 10:01 AM   #11
LockDoc
The Older Generation
LockDoc's Avatar
If the ignition cylinder returns to the run position from the start position it's OK.
LockDoc
Leon
Old 06-16-2008, 10:23 AM   #12
Wrenchbender Ret
I used to get them like that ever so often & finally figured there must be a short in the coils in the starter. The only way I could fix them was to replace the whole thing. It could be like N TRux posted & need shims but the starter keeps grinding even without the engine running & shuts off after you pull a cable if it hasn't burned itself up by then.
Wrenchbender Ret is offline   Reply With Quote
Old 06-16-2008, 01:43 PM   #13
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
You have the little wires on the sol reversed, one is "S" from the key and the other is "R" or "I" that goes to the coil. if you swith them it will keep the starter engaged.
sneakysnake is offline   Reply With Quote
