Old 06-15-2008, 11:57 PM   #1
19gmc67
19gmc67's Avatar
Question wiring question
do the wiring kit work on engine swaps.my truck has a olds 350,but the truck needs to be rewired.need info hate to spend the money and it not work.thanks for the help!!!!!!!!!!!!!!!!!
heres the truck
heres the motor
and heres the chicken scatch wiring
19gmc67 is offline   Reply With Quote
Old 06-16-2008, 12:03 AM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: wiring question
The only thing I can see is if your sensors are in a different location. Then the new harness may not mach up.
You probably don't have anyway to tell for sure what's different. You might just have to get one and extend any wires that don't match.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 06-16-2008, 12:59 AM   #3
Sinisterspeed
Sinisterspeed's Avatar
Re: wiring question
Well as far as the engine the only thing you need to make it run is a starter wire (which should be in the same place since its still a GM motor) looks like you have an HEI on there. No wire for that in the factory harness anyway. and the alternator wiring which is long enough to run the alternator on either side. Usually if your running an externally regulated one and its working run it. If not switch to a single wire alt (add the wire) and run it to the battery following the factory harness over to the batt.
So rewiring your truck will fix other wiring issues but as far as the engine I don't think it is going to matter which engine you have in there you will be making or extending the same wires either way.
but one other thing those fenders and that core support aren't going to work together. I did the same thing, Almost ready for paint and thanks to Andy I looked into closer. Those fenders wont work with the GMC grill that goes with that 4 headlight set up. Should probably pick 2 headlights or 4 before your wiring the headlights.
There are two kinds of people, those who finish what they start and so on.
70 GMC Longhorn (A.K.A Money Bucket)
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
Dad's Budget Build 55
My Longhorn Build
Sinisterspeed is offline   Reply With Quote
Old 06-16-2008, 10:29 AM   #4
19gmc67
19gmc67's Avatar
Re: wiring question
thanks 4 the info,how would i go about wiring up the hei if there no wiring for in the factory harness.
Old 06-16-2008, 01:28 PM   #5
Sinisterspeed
Re: wiring question
All you need for the HEI is 12v+ ign power to make it work. On the cap there is a square part that sticks off and has two terminals under it. The cap should be labeled in the plastic molding 12+(or batt)/tach. Thats it. just make sure you don't have 12v+ when ign is off or you will burn it up pretty quickly.
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
My Longhorn Build
Old 06-16-2008, 01:43 PM   #6
19gmc67
19gmc67's Avatar
Re: wiring question
something like msd ignition box or something of that nature
Old 06-16-2008, 02:15 PM   #7
19gmc67
19gmc67's Avatar
Re: wiring question
bttt
Old 06-16-2008, 02:44 PM   #8
19gmc67
19gmc67's Avatar
Re: wiring question
bttt
Old 06-16-2008, 02:47 PM   #9
Sinisterspeed
Re: wiring question
They are nice but not required.
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
My Longhorn Build
