Oil tube broke off
Ok so heres what happend..I had my bottom end resting on the crank pulley while I was bolting it to the engine stand and it fell over...The oil tubr that runs into the block bent and sanpped off...how do I get the old one out, and the reinstall the other? and my last ? where can I get that part?
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
Re: Oil tube broke off
Dave's not here, man
The last one I got was from the dealer, but it was an '86 block. It was a dirty beeyatch to get the old tube out. Had to pull the pan and try tapping it out, which worked partially. Then I ended up using a drill bit that was just a tad smaller than the hole the tube goes in and it grabbed the broken piece and spun it out of the block. I hope it isn't that bad for you as I probably just got really lucky.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
#4 | |
Gone to greener pastures
![]() Join Date: May 2007
You might want to take a propane torch and heat the block a little bit also. Decide when you are going to install the new tube, then put the tube in the freezer the night before. Most auto supplies carry after market tubes & dipsticks. You'll probably have to buy both of them, though.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 06-16-2008 at 06:04 PM. |
Easy....drop the pan and tap it out from underneath....you can get a replacement at any O'Reilly's [or some dealers have the stock ones].
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
Phone's ringin Dude.
![]() Join Date: Mar 2007
Mine had a little lip left to it, so I just popped ita couple times with a flat screwdriver and hammer, then grabbed it with a pair of vice-grips
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
Sierra Grande Club
I would avoid pulling the pan or heat.....try the easy out with some penetrating oil.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
I use a large sheet metal bolt with a hex head. I screw the bolt in and then use claw hammer or similiar tool to pry it out. I have done several this way with no problems.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Thread a screw or bolt into it like Jim said, then put a small open-end wrench under the bolt head and tap the wrench head upward with a hammer.
Never thought of that one Jim....not a bad idea actually. I'll have to try that next time...sure beats dropping the pan. Mine happened to coincide with a pan gasket change.
