06-16-2008, 11:44 AM | #1 |
anybody cut the upper crossmember spring pocket?
Whats happening?? I am looking at ways to get my current 67 project lower in the front... Its bagged with a kp notch in the rear.. I am on the fence about z'ing the frame right now.. I may go that way but at this point not ready to make the cut... I see a lot of guys are cutting the lower control arms apart and welding a cup for the bag to sit lower in.... Has anyone cut the upper side of the crossmember where the plate/bag mount bolts in and move it up higher? Looking at the frame it looks like it should work... I know you can never run a coil spring again but thats not an issue... Thoughts???
Look at the second pic for an Idea of what I mean... (jacked from backyard88's build thread.. Thanks... )
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile Last edited by c10addict; 06-16-2008 at 11:57 AM. |
06-16-2008, 03:16 PM | #2 |
Re: anybody cut the upper crossmember spring pocket?
I know @ least one board member that did his.
06-16-2008, 05:15 PM | #3 |
///Relaxed Atmosphere
here is a link to one that has done this.
http://67-72chevytrucks.com/vboard/s...=266234&page=3 I know i should have some pics of others that have done this here in houston and can share soem photos of once i get to my home computer.
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
06-16-2008, 05:23 PM | #4 |
Thanks! I felt like John Madden on Monday Night Football drawing those lines on the crossmsmber pic..... BOOM!!!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
06-16-2008, 05:53 PM | #5 |
soon to be bagged64sub
There is a guy around here that did it too. The only thing I noticed is that he had alot more negative camber then I did. Just Z it and get it over with.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
06-16-2008, 07:41 PM | #6 |
Cross member section... No camber change. ...or Z I'm going for the former.
06-17-2008, 09:55 AM | #7 |
Epoxy Primer Friendly
I cut the cups off flush, then plated it and added these upper mounts. [IMG]http://*****************/images/products/mid_Rear_Upper_Bag_Bracket_Dual_Port.jpg[/IMG]
06-18-2008, 05:44 PM | #8 |
On the fast track to nowhere..
Just do the Z, you know you want to
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
06-18-2008, 07:32 PM | #9 |
here are somes of what i have on file
06-19-2008, 08:22 AM | #10 |
Im picking up some steel tonight.... Lol... Here we go again! Any pointers??? 2.5 seems to be the norm....
06-19-2008, 08:23 AM | #11 |
Thanks for the pics! Dunno what I would do without the board and the great people on it!!
06-19-2008, 12:48 PM | #12 |
I did 3 to be safe but I'd think 2.5 would work. Although, what's another .5 inch Better safe than sorry
06-19-2008, 01:14 PM | #13 |
That .500" could be the difference between making a new trans tunnel because everything hits or tweaking the exisitng tunnel because one area hits....
06-19-2008, 02:21 PM | #14 |
I def. see where you're coming from. In my case I'm already doing enough cutting on the frame that some extra sheet metal work is no biggie. I also bought a high hump cover just in case
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting Last edited by BACKYARD88; 06-19-2008 at 02:25 PM. |
06-19-2008, 02:24 PM | #15 |
I got me one of them there high hump tunnels on the shelf... Looks like I should go 3 then...
06-19-2008, 02:30 PM | #16 |
Well, like SCOTI said, it may cause you more work on the tunnel if you do. I don't have much factory stuff on mine anymore(engine mounts etc) so I just made sure I could get the frame down and I'll tackle the rest as I go. I guess it just depends on how much work you're willing to do. If it's a concern for you, mock it up and don't do more than what you need
06-19-2008, 02:35 PM | #17 |
Once I get it to lay I am afraid I will want to pull my 68 off of the frame and swap it over!!!
06-19-2008, 02:50 PM | #18 |
Don't feel bad, mine was supposed to be a 4/6 static drop when I started
