best paint stripper
What is the best paint stripper to use and where do you buy it? I'd like to get away from having to scrape it 4 or 5 times. The flat spots aren't that bad, but the nicks and crannys kill me. What's the best?
so easy a caveman can do it...
![]() Join Date: May 2006
Re: best paint stripper
I've used citri-strip with good results
Aircraft stipper, without a doubt. Very smelly. Use gloves. Most auto parts stores have it.
the aircraft stripper is about the best i've found autoparts stores and biiger containers at autopaint suppliers//very toxic and burns on bare skin but rarely have i need to do a second coat with it
Alright Alright Alright
i also use the aircraft paint remover. not only does it remove paint, it also disolves grease, gunk, carbon and oil buildup on engine components.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
This is what I've always used......
http://www.auto-ease.com/cgi/ppcart....57094&cleaners Has been around for over 30 years. I've stripped many vehicles with it.
1997 GMC Sierra Ext 1965 Mustang |
CAN'T FIX NOTHIN
what are you trying to strip ?
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
Mr Muscle oven cleaner to clean parts. Use it outside spray on and keep wet. Keep wet twice recommended time and pressure wash it off. This is how I get things ready for powder coat. I stripped black off GMC grill with aerosol can of aircraft stripper from NAPA.
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
which ever you use, put a trash bag or some other plastic over what you applied to keep the stripper wet and keeps the fumes under cooking the paint off.
Still livin the "dream" in '54
I find that the best paint stripper is to hire some punk for min wage and put him to work with a sander....
![]() Chemical stripping is a MESS! It sucks, no matter what you use and how you do it. And there is no such thing as a 100% paint stripper, they always leave something left that needs to be sanded off so... I'm going to recommend a 8" hawg with 80 or 40 grit. Keep it flat and then finish with 80-150 6" DA. Alot of work yes, but at least you won't have the goo left over from the chemicals. D
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo Last edited by Richard8971; 06-18-2008 at 09:52 PM. |
you could also hire some ILLEGALS. Of course, they would strip it down so good you'd need some concrete blocks to keep it off the ground!
#13 | |
D
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
#14 |
I have used a product called "Dads" comes in a dark blur can and usually comes with a small pump bottle sprayer spray a 2ft sq area cover with sarna wrap (you can see thru and see it working) uncover scrape redo and move on them when most of the heavy stuff is off scrub with steel wool and wipe clean with box of rags paper rags LOTS of work then you should detergent and hot water wash LOTS more work You start to rethink using a professional stripping service the next time! But it can be dun !
#15 |
... 80 grit works for me ... plus it makes all of this cool looking dust like stuff
#16 |
Rottenwood Garage Member
I love all types of strippers!
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
#17 |
![]() Join Date: May 2007
i have found that aircraft stripper works well .... i also use as wire wheel on a variable speed drill instead of a scraper... i can be real messy if you try it with a wire wheel on an angle grinder! if you take your time with the drill and wire wheel you can get it down to bare metal and it even eats through body filler at the same time. wear long sleeves!
1966 Chevy C-10 Fleetside Check out http://jcox.tumblr.com/ for progress updates! |
#18 |
what about that soda blaster that they used on trucks
I want one if it really works like that you can buy it at eastwood any of you guys have to start pushing people out of your garage because of the cost of letting people use your stuff |
#19 |
Barrito Loco Diablo
I started sanding the hood down on my truck using a 4" palm sander and gave up after a couple of hours. lol. I have at least 8 layers of paint i'm cutting through. Guys at work keep saying to use the aircraft paint stripper found at the parts stores. My concern was with the waste of this stuff. If it burns skin, what is it going to do to my driveway when i hose it off? i don't want it seeping into the yard or gutter. Or does this stuff all dilute with water?
#20 |
Redefining LowBudget
sode lalsting is the way to go check around there are guys that will come to your house and do it for cheap $$$ ( and Ima cheap skate) leaves a mess that you can clean up with a broom in 20 min...No taping no dust no mess and done in about 2 hours Oh and di I mention it shines the hell out of chrome and glass with out a scratch!!!!!!!!
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#21 |
The latest news is soda blasting is out ... apparently it's been discovered that paint does not stick well to sheet metal that has been stripped with soda and there is practically no way to clean it well enough to over come this.
#22 |
aircraft remover for sure...i sprayed two coats of that on my frame and scraped/pressure washed between coats and it looks just as good as sandblasting, im sure it will work great for body parts as well, sure beats sanding but wear gloves and safety glasses for sure, its some nasty stuff it will burn your skin almost instantly if you get it on you....trust me i know. and if you get it in your eye.... i can only imagine
#23 |
low n' slo
![]() Join Date: Mar 2009
so aircraft paint remover is basically like sandblasting just with a chemical? hmm, where can you get the kind that comes sprayable? I seen the kind at the paint store but I didn't know you can spray it...you just put it in your gun? also, would it strip factory caulk and stuff...like the crap they stick in the hatch area of the suburbans?
#24 |
![]() Join Date: Nov 2003
When did this news come out? I have been out of the hobby for a little while. Is there an article somewhere that I could read on it?
#25 |
not anything you can read about it. It has just kind of filtered through. Soda blasting has been out long enough now for people to see the results happening. The soda is caustic. if you dont get it cleaned off and out of EVERY crack and crevice it will sit there and eat away at the metal. It will cause a completely redone car to rot out in just a few years.Even if they are stored inside. The soda attracts and retains moisture. Most paint manufacturers will specify on there tech sheets not to use there products on soda blasted metal. I, personally, think it is because of prep and not because of the products not working. They are covering there butts because too many jobs have come back because people DID NOT prep the vehicle right after having soda blasted. Media blasting with plastic/glass beads is the best way.
