Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-16-2008, 07:39 PM   #1
PA-IndianRider
PA-IndianRider's Avatar
One more Piece of the puzzle
After "striking out" at the Parts-a-Rama swap meet over the week I was able to find a good deal on Craigs List for a narrowed 9" F**d rearend & Summers axles (with 5" Chevy bolt pattern).
After measuring the C10 and the wheel/tire combo I plan on using I realized this housing will work with what I plan to do .... made the call this morning and now it's mine.
So little by little I am gathering what I need to take our C10 from street cruiser (my original plan) to the drag strip..... so even though the BIG SWAP meet was a BUST it's been a good week or so on Craigs list.... BIG Weld wheels & slicks, 400 Turbo trans with manual shift body & 4000 stall convertor & now the rearend.
Having a HARD time finding 15 x 3 1/2" - 4" or 5" .... front wheels with 5" bolt pattern .... finding all kinds with 4 3/4" pattern ...... as you can guess trying NOT to buy NEW to get what I want.... so far I have been doing pretty good at doing that.
Guess I could switch to a 4 3/4" front spindles .... who knows ..... still keep having thoughts of a "straight front axle".... especially after going to the "Gasser Reunion"....HA!!!
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 06-17-2008, 10:11 AM   #2
kwhite4
Junior Member
kwhite4's Avatar
Re: One more Piece of the puzzle
What size rear wheels are u gonna run?
68 GMC
565 BBC
Abruzzi super pro glide
9.85@135.00
kwhite4 is offline   Reply With Quote
Old 06-17-2008, 12:13 PM   #3
71Dragtruck
71Dragtruck's Avatar
For fronts if you find some Center Line Auto Drag's you can have another pattern drilled. So if you come across a 5x4-3/4 or 5x4-1/2, you can have a 5x5 added to them, just messure the center hub hole and make sure it will fit, sometimes a spacer will take care of that also.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 06-17-2008, 04:39 PM   #4
bigjimzlll
bigjimzlll's Avatar
I can't tell from the pic, but what spline are the sumer's axels? I run a set that are 17 spline but are very thick. The problem is you can't get a spool to fit them.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 06-17-2008, 10:26 PM   #5
PA-IndianRider
I am all set for what I am going to use in the rear for mock-up and plan to build around these to get started with:
15 x 14" Weld wheels with 33" x 15" Goodyear slicks for the strip....
And for the occasional street cruising and show going:
15" x 14" modified Rally wheels (previously used on a pro street Vega) with 32" x15" Mickey Thompson Sportsman tires.
I'll keep looking for those "skinnys" for the front....still plenty of swap meets to go to before this project is ready for having tires mounted on it.
BTW... finally picking up my MillerMatic 180 this weekend..... now where is that "sawsall" ????
John aka "Milner"
Old 06-17-2008, 11:41 PM   #6
PA-IndianRider
I'm going to pickup the rearend later this week (bought it from the same guy I got the Weld wheels & slicks from - Craigs List).... so I'll let ya know then.
Another bonus.... a long-time drag racing friend of mine who runs a 9 second Mustang (all motor) is on-board to help me figure all this stuff out and has been using a 9" F**D rearend and done a couple of back-halfs.
One thing I have learned is you cannot BUY experience.... that's just one of the MANY reasons this forum ROCKS!!!!
John aka "Milner"
Old 06-25-2008, 12:34 PM   #7
lowriden58
lowriden58's Avatar
Weld still offers a 15x5 with 5x5 pattern, not sure if that backspace would work or not. worth checking into
http://www.weldracing.com/wheels/det...loy%20Polished
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
