1967 327ci short block
I have 1967 327ci short block, its need rebuilding. Block is already 0.30 over.
I took it out of 72 p/u several years ago. It was running, used oil. Not sure if crank has been turned. Here are all the numbers on it: T02I3HC 7R145765 3903352 Shows to be 1967 327 ci, 2 bolt main, small journal. I wanted to re-build but will prob just go with a stock GM crate. $300 or possible trade for a good TH350 tranny.
1977 Camaro 468 BBC - SOLD - 1972 Chevy SWB....in the works!! ![]() 2006 Crew Cab Dmax/Allison Summit White-SOLD- 2009 Toyota Tacoma V6 Pre Runner - daily driver - my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595 Last edited by 72SWBChevy; 06-17-2008 at 07:26 PM. Reason: .030 over not 0.40 |
![]() Join Date: Dec 2007
Re: 1967 327ci short block
wish you were closer, I have been looking all over hell for one of these up here.
Andy... '70 C/10 Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=298553 '71 K/20 Frame-off resto, SOLD!!! http://67-72chevytrucks.com/vboard/c...ct=2399&cat=12 '05 Silverado Z-71, CC SB, Daily Driver |
ttt
1977 Camaro 468 BBC - SOLD - 1972 Chevy SWB....in the works!! ![]() 2006 Crew Cab Dmax/Allison Summit White-SOLD- 2009 Toyota Tacoma V6 Pre Runner - daily driver - my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595 |
any offers?
Confused but Happy
![]() Join Date: Apr 2008
what part of houston are you in. I am about an hour south of houston.
I am located in north Houston, at 610 and Ella. Zip 77018
$200
610 and ella, we are neighbors. I'm at 43rd and ella. If I had room or needed one I'd be all over it.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 06-30-2008 at 02:18 PM. |
jorgensc - Yea I bought the core support from you a few weeks back..tks
yes, I have a bad memory!!! Sorry about that. How is that working out for you?
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Working out good, I welded up a few of the extra holes in it and want to send it and the inner fenders out to get powder coated,
