Old 06-17-2008, 02:32 AM   #1
azfab
azfab's Avatar
86 c10 efi
has any one susefuly transplanted a tbi motor in a square body? whats in volved in doing so thanx guys
azfab is offline   Reply With Quote
Old 06-17-2008, 08:17 AM   #2
D13
D13's Avatar
Re: 86 c10 efi
GM did it in 1987, and in 1 tons burb and blazers 87-91.
Fuel sender and return line, change heads and intakes (or redrill, or use an adaptor plate intake to TBI), different distributor, add knock sensor if your block doesn't have one, add ECM and all wiring, O2 sensor, etc.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 06-17-2008, 09:40 AM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: 86 c10 efi
Mines factory, look at the last line of my siggy. Get yourself an 87 computer, harness, and donor engine, and you've got it made. Or, you can buy a kit from Edelbrock for about $3000.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 06-17-2008, 02:46 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: 86 c10 efi
Yep it can be done and its not that hard. Heres a link to check out. http://www.automedia.com/TBI_Fuel_In...ht20001001fi/1
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
