Thats the Hillbilly way
Clunk making a right or left into driveway
I've been getting a loud CLUNK when making a right or left into a driveway or a street that has a slight dip ,anyone else ever have this ? Carrier Bearing ? U-Joint?
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
depends on where the noise is coming from.... could also be A-arm bushings going bad or something else loose in the front end.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
![]() Join Date: Sep 2001
I second the control arm issue. That was my "clunk". It was really metalic, and I'd generally hear it when pulling away from curbs and stuff. Turns out one of the metal bushings on the lower control arm center bar was totally ovaled out.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
Member since 2000
is your dana 60 a posi? cause some time you got to ad a additive that helkpt he springs. my posi somtime would click on slow turns. it was my posi.
I had a loose stearing box on my k-10 that made a klunk when making hard turns.
A broken upper shock mount on the sub that klunked. And all the alignment shims came out one time on my 2wd and that klunked when turning and braking. Randy ![]() ![]()
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
SLOW BUT SURE,BUT CLOSER
I was thinkin' posi too!!!!!!
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
Real Deep...
A few other thoughts
Could possibly be the spring not seated just right in the perch. Mine's done this before. Does it and mysteriously goes away, no real good reason for it.
I agree with the shock mount, as it's a continual pain in the tookus (whoever came up with that design should've been shot, stabbed, drawn and quartered and left in an unmarked grave...).
1970 GMC C10 (Deep Purple) 383/700-R4 Mass Modifications 1976 GMC K5 Jimmy (Big Blue) 400/TH350 Coming soon to a drive-in near you... We have done So Much with So Little for So Long.. We are now qualified to do Anything with Nothing. |
its all about the +6 inches
I've had ball joints clunk in the turn/hill situation before...
Lucily, clunking is the only bad noise my GMC has not made as of yet. (knock on woodgrain) |
#9 | |
Bloo
upper balljoint does that on the 89, and the right tie rod section
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
