06-17-2008, 09:18 PM | #1 |
the pollock
WTF? is this thing
hey guys
i was diggin through my dash and found a random bulb hanging on what appeared to be a cable connected to my ashtray coin tray area well said cable was basic plastic version of fiber cable, it took the light from the bulb and put it into the coin tray is this like a sneaky way of making sure that people are not just hiding the check engine light? i still have the bulb holder and cable if you need pictures.. but what in the world is it?
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
06-17-2008, 10:02 PM | #2 |
I don't think these pills work
Re: WTF? is this thing
my 84 has it it just uses the light from the dash to light up the ash tray so you know where to ash at
SQUARE84 90 SUBURBAN |
06-17-2008, 10:21 PM | #3 | |
the pollock
thought it was somethign else whoops retard me.. thank you
06-17-2008, 11:14 PM | #4 |
Chevys Kick A$$
LOL ha yea sounds just like a light for your ashtray to me.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
06-18-2008, 10:01 AM | #5 |
Arrived on a Pale Horse
If you leave it out, Cheech and Chong won't be able to raid your ashtray for roaches.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
10-12-2011, 08:42 AM | #6 |
How much light does this put out? I don't even see a bulb...
'85 Silverado, 4x4, SB 350. Keep them beavers grinnin' and them wheels a spinnin'! |
10-12-2011, 09:24 AM | #7 |
78K & 79C Jimmys
if thats a fiber optic cable then follow it back to the bulb it gets it light from
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
10-12-2011, 10:41 AM | #8 |
It is a fiber optic light connected to the back of one of the instrument panel lights. You have to look real close to see the small amount of light it provides for the ash tray. I don't see how it has any value, since you can barely see the light - if you need to use it for your cigarette/cigar ashes I guess it might help some. Some vehicles in the 60s -80s had an actual courtesy light controlled by a switch in the center of the dash which could double as a map light which I think made a lot more sense.
10-12-2011, 10:57 AM | #9 |
Strange. It has a black tip. I don't understand how light passes through it. I'll check it out in pure darkness sometime.
10-12-2011, 12:06 PM | #10 |
I know the pieces fit
I had an 83 once that had the light still working and I was smoking in the car back then. It worked well.
10-12-2011, 04:11 PM | #11 |
78K & 79C Jimmys
it would dim with the dash lights too
very faint but see-able(if thats a word lol) at night if the glass of the bulb is burnt,or burnt out it will be darkish but you can take it out, and try it,holding it to any light,and the light will bend threw the "tube" of "glass". these days the high tec fibre optics is ajusted for best light/signal coming threw back then it just went "in the hole"
10-12-2011, 08:30 PM | #12 |
78K & 79C Jimmys
not a good shot just happened to find the source for that "light" in my 89
and it turns into the cluster
10-12-2011, 10:51 PM | #13 |
yep. the fiber optic cable that almost everybody asks about. Even me. I thought it was a cut wire at first.
Perfectionism and owning a square is the worst possible combination for a person as broke as myself. |
10-16-2011, 08:58 PM | #14 |
11-09-2014, 08:10 PM | #15 |
I know this is an old thread, but i have this thing hanging lose with no bulb. Where in the cluster does this go?
http://67-72chevytrucks.com/vboard/a...1&d=1318465812 |
11-10-2014, 01:59 AM | #16 |
I believe it goes into a socket behind the fuel gauge. Picks up power from the circuit board. I removed mine when I installed LED's.
11-10-2014, 02:06 AM | #17 |
I'm putting in LED's also and adding a clock. I got the whole cluster out and then I found that just hanging there.
So I'll put an LED in it and reattach to the cluster when I put it back together. |
11-10-2014, 09:55 AM | #18 |
My 87 had one. It went to a bulb in the dash, and then to the shift indicator.
11-10-2014, 11:12 AM | #19 |
I was thinking the LED's I used were sort of "directional" and the fiber optic wouldn't pick up any light from the side of the bulb so I just left if out. May add a small LED for the ash tray in the future.
11-11-2014, 09:55 AM | #20 |
78K & 79C Jimmys
It's usually stuck in a top right cluster hole
and over to a small square hole over the ashtray
11-11-2014, 10:10 AM | #21 |
It might be black on the end from someone hitting it with a cigarette.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
11-11-2014, 05:16 PM | #22 |
You should try it, you might be surprised. They actually work pretty good - give a nice, low level illumination to the ashtray area.
Not really sure of their purpose however - maybe to help guide your smoke to the ashtray when it was time to flick the ashes off. Never needed it, I always used the vent window for ash flicking. |
11-11-2014, 06:10 PM | #23 | |
That fiber optic cable stuff is pretty cool. My Cadillac had them on the fender markers and above the rear window, so you can tell if bulbs or headlights are blown out from the drivers seat.
