Radiator Support mounting diagram???
Does anyone have one? my truck is a '66....should be the same from '60 to '68
Thanks, Joe
Re: Radiator Support mounting diagram???
ttt
Junior Member
Sorry for the poor scan quality. They made the pages so thin in the manual the other page always bleeds thru...
Thanks Curt,
I'm trying to see the mounting to the frame. don't see them there
![]() Join Date: May 2007
i just bought the mounting hardware kit from LMC and it has a sheet that shows the proper order for the hardware included... i can scan and post it for you, but i wont be able to do it until friday morning! let me know!
the way mine was mounted when i bought it was way off. the kit actually raised the radiator support on washers and rubber washers... maybe 1/4inch or so!
1966 Chevy C-10 Fleetside Check out http://jcox.tumblr.com/ for progress updates! |
#6 | |
I think my mounting may be too high, or my cab mounts too low. my fenders don't line up with the cab. Looks like thicker than 1/4" rubber between the frame and core support, so I'm hoping that is the problem
i couldnt find the diagram for the mounting hardware like i said i had... so i took mine appart and snapped a few pics. hopefully this helps!
the space between the bottom of the radiator support and the top of the frame is 7/16"... the metal plate once you have everything where you want it, you are suppsoe to bend the tab down to lock the nut in place... i havent done that part yet. ![]()
1961 crewcab
Good info STL!
I am going to check mine too. |
hell yeah that helps a lot, thanks mucho!
no problem! glad i could finally give back after all the questions i have asked!
