Old 06-18-2008, 12:09 AM   #1
lifted 75 k5
lifted 75 k5's Avatar
have a couple questions about my truck
ok i have a 75 k5 blazer lifted on 37s and i want to change the qudra junk carb so what is the best carb to go with. for the most part it is my daily driver but i do take it off road once and a while. thanks for your help
lifted 75 k5 is offline   Reply With Quote
Old 06-18-2008, 01:16 AM   #2
Square84
I don't think these pills work
Square84's Avatar
Re: have a couple questions about my truck
imo it depends on mechanical ability. edelbrocks are easy no tune carb but not that great off road. holly is great all around carb but the ones ive had required tuning constantly.
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 06-18-2008, 10:26 AM   #3
lifted 75 k5
what about the holley quadra jet replacement i heard it was a good carb without much tunning is this true
Old 06-18-2008, 11:19 PM   #4
Square84
Square84's Avatar
on the quad there is not just a whole lot of adjustment to them but they are great carbs if they are built right
SQUARE84
90 SUBURBAN
Old 06-18-2008, 11:50 PM   #5
Kaysenmc
Kaysenmc's Avatar
Just rebuild and run the Q-jet, unless your pushing those 37's with some big power. My Q-jet equipped k-5 has really good power with 36's and Im getting 13.8 Mpg on the highway.
87 black silverado swb, tbi 350, 700r4, 3.40 gears. 2.5 drop spindles , 2 inches off stock coils, flip kit out back. cragers with radial ta's... ongoing piddle project!
1970 Olds rallye 350, street strip 403/350 3.73 posi. Looks stock/runnin 12's!
86 K5- SOLD!
Kaysenmc is offline   Reply With Quote
Old 06-19-2008, 10:59 AM   #6
lifted 75 k5
yea i am putting 37s on my truck but i was thinking about the holley avenger maybe or the holley q jet replacement
LIFTED OR LOWERED EITHER WAY STOCK SUCKS
75 Chevy blazer
86 trx 250R
1990 Ford Ranger 2wd prerunner project
Old 06-19-2008, 02:55 PM   #7
tobiahr
tobiahr's Avatar
I was reading the thread and wondering who convinced you Quadrajet were junk? I might not be a professional mechanic but have been around long enough to know that what looks cool, is popular and what works best isn’t always the same thing.
If you are looking for a easier to adjust carb go with Edelbrock. The Holleys are a little easier to adjust than a Quadrajet but perform about the same as a well adjusted Quadrajet. A properly adjusted Quadrajet will perform as well as any other brand under most circumstances. If you truly want the best performance, tuning and mileage you need to go with electronic fuel injection.
tobiahr is offline   Reply With Quote
Old 06-20-2008, 01:31 AM   #8
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I would say go with a quadrajet or Edelbrock those are my 2 choices.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 06-21-2008, 08:47 PM   #9
screwballl
Tonawanda 454
screwballl's Avatar
I have had good luck with Edelbrock myself both on and off road.
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 06-22-2008, 10:20 PM   #10
lifted 75 k5
so the edlebrock sounds like the best way to go for on and offroad and easist to adjust
75 Chevy blazer
86 trx 250R
Old 06-23-2008, 12:08 PM   #11
Richard D
Richard D's Avatar
Keep the Q-jet.
Richard D is offline   Reply With Quote
Old 06-23-2008, 12:12 PM   #12
tobiahr
tobiahr's Avatar
keep and rebuild the quadrajet
Old 06-23-2008, 04:40 PM   #13
lifted 75 k5
ok so the q jet is the best should i just buy the rebuild kit
75 Chevy blazer
86 trx 250R
