Old 06-18-2008, 01:12 AM   #1
65chevy4x4
step side fenders
Is there a special tool to take step side fenders off the bed?Or what is the best way to take them off?--Thanks
65chevy4x4 is offline   Reply With Quote
Old 06-19-2008, 12:49 AM   #2
PDW HOTRODS
PDW HOTRODS's Avatar
Re: step side fenders
They are just bolted on, but they use clutch head bolts. You can get clutch head screw drivers at Sears, but these days they might not keep them in stock.
PDW HOTRODS is offline   Reply With Quote
Old 06-19-2008, 01:46 AM   #3
CAL 58 GMC
CAL 58 GMC's Avatar
Here's a set I found on e-bay. http://cgi.ebay.com/ebaymotors/Clutc...spagenameZWDVW
CAL 58 GMC is offline   Reply With Quote
Old 06-19-2008, 02:48 AM   #4
mr48chev
mr48chev's Avatar
I think I picked up my last ones at Ace hardware. You should also be able to get them at Sears but may have to order them. You should be able to find some bits that you can put in the adapter and use on a small ratchet.
Snap-On has some nice ones but they are a bit spendy. http://buy1.snapon.com/catalog/item....re&dir=catalog
Also get up under the fenders and spray some PB blaster on the nuts after you brush them and the head of the screw/bolt off with a wire brush first. It will save you a lot of grunt and groan and probably help save the clutch head screws to be used again.
Old 06-19-2008, 09:35 AM   #5
65chevy4x4
Thanks guy's---Now i know what kind of tool to get.
Old 06-19-2008, 07:48 PM   #6
orgalmeister
Also check your local NAPA.
'56 truck (the never ending project)
'06 Z/71 loaded (daily driver)
'07 Mercedes-Benz C-Class (wife's driver)
Gone: 72 SB, 67 CST, 57 BBW, 47 Panel streetrod,
orgalmeister is offline   Reply With Quote
