![]() Join Date: Dec 2007
frame prep.. rivets..
so my frame needs lots of massaging with the flapper wheel to get rid of 38 years worth of rust and dust, and I was just wondering what you guys think of drilling out the rivets in the crossmembers and removing them for prep and paint, then reinstalling them with gr.8 or higher hardware?...
has anyone done it? pics? and what is the best way to go about it? thanks in advance!! Andy
Andy... '70 C/10 Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=298553 '71 K/20 Frame-off resto, SOLD!!! http://67-72chevytrucks.com/vboard/c...ct=2399&cat=12 '05 Silverado Z-71, CC SB, Daily Driver |
Tasty Cakes!
Re: frame prep.. rivets..
Don't see why not. Have fun with that though.
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado Last edited by Riveted1; 06-18-2008 at 02:43 AM. |
nice modified.
drive it till it dies
drilled out a couple rivets the other day, it sucked.
Chevy nut
I grind the heads off with and angle grinder. Then popped the rivet out with a punch and a hammer.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
#6 | |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Andy, I agree with 68alltheway. Drilling out rivets does suck and also agree with caminokids' method. Thats the way I removed my rivets. In addition to my auto tranny cross member, I did an entire leafs to coils swap and used all Grade 8 hardware including the trailing arm brackets on the main crossmember. Go for it , Grade 8 bolts will do the job.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 06-18-2008 at 07:18 AM. |
![]() Join Date: Apr 2008
I have replace rivets with grade 8 on a 74 f100 and used it as a work truck for many years.I used lock washers then set the nut with a punch and they never moved.
![]() Join Date: Jan 2007
Member 'msgross' did that on his frame rebuild -
see pix in this thread starting with post #59 on - http://67-72chevytrucks.com/vboard/s...=242910&page=2 |
Arrived on a Pale Horse
You can use a pnuematic cut-off tool to make an "X" on the head, then a couple taps with an air chisel and they pop right off of there.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I wouldn't use grade 8 bolts. They are too brittle and when your frame is flexing they could enlarge the hole. Rivets are manufactured from soft tooled steel, and used to maintain the flexibility of the frame without stressing the holes. Bolts that are too hard can brake, and the can be very abrasive to the holes themselves. I always use grade 5. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
thanks
![]() and to everyone else, thanks for the input ![]() ![]()
