Old 06-18-2008, 04:09 AM   #1
68alltheway
drive it till it dies
68alltheway's Avatar
door hinges??
what is an easy way if any to fix sagging doors. my drivers side door rubs on the bottom of the door jam when i close it. its already rubbed some of the paint off.
live life to the fullest
68alltheway is offline   Reply With Quote
Old 06-18-2008, 04:25 AM   #2
1969-08 chevy
1969-08 chevy's Avatar
Re: door hinges??
If you open the door and gently move it up and down you can see if the play is in the hinge and pin itself or if you just need to re-adjust your doors through the hinge bolts. I have had my doors on and off quite a bit, and they are a pain to get lined up rite.
1969-08 chevy is offline   Reply With Quote
Old 06-18-2008, 06:59 AM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: door hinges??
I am going to hazard a guess that it is the hinge pins that should be replaced, not the hinges. At least, they're cheaper and may be all you need to do. If not, you'll know what to do.
Member Nr. 2770
Old 06-18-2008, 07:21 AM   #4
70GMCer
70GMCer's Avatar
Re: door hinges??
Advance Auto & Auto Zone & others, have door hinge kits for around $10. Also, you can get the hinge bushings from GM dealers.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-18-2008, 07:51 AM   #5
70c10
67-72 Addict!
70c10's Avatar
Re: door hinges??
I didn't realize I could get these locally at the parts stores. I thought I had to go to the dealer.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-18-2008, 08:01 AM   #6
Number98
Prestige Worldwide
Number98's Avatar
Re: door hinges??
I got this from http://www.earlyclassic.com for $8.00.......
Should fix you right up!
Number98 is offline   Reply With Quote
Old 06-18-2008, 07:09 PM   #7
72lb4x4
Re: door hinges??
If there's a red help section the P/N is 38400. You'll need 4. For example:
http://www.rockauto.com/catalog/rafr...0&a=FR42-38400
BTW: The old pins can be pretty easy, or really hard to get out.
72lb4x4 is offline   Reply With Quote
