Old 06-18-2008, 12:15 PM   #1
stunna
rear fender well clearance
If i put 22x10 rims on the rear and lower the rear using air with the stock trailing arms and all nuthin fancy, but i will be raising bed about 3-4 inches to get maximum drop of bags, will i need to widen the factory wheel housings or can they accomodate 10 inch rim width?
stunna is offline   Reply With Quote
Old 06-18-2008, 03:07 PM   #2
stunna
Re: rear fender well clearance
anybody?? All the wealth of knowledge on this site i cant believe noone knows the answer to this question.
Old 06-18-2008, 03:42 PM   #3
neonlarry
neonlarry's Avatar
I don't have 22's but I do have 10" wide rims and they fit the stock wheel wells.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-18-2008, 03:56 PM   #4
c10addict
c10addict's Avatar
whats the offset of the wheel????? What size tire are you running...... The info is on here you just have to give more details...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 06-18-2008, 04:46 PM   #5
stunna
the tire size will be 255?35?22, im not sure about the offset on the rims but i think its 5.8?
Old 06-18-2008, 05:07 PM   #6
VA72C10
VA72C10
VA72C10's Avatar
There are several guys on here running 10" wide rims, the offset will be the main issue. Need to have the info. on that. And from what i've read, even then every truck can be slightly different. What rear end are you running? THat can make a difference as well as they are differing widths based on the year/type.
VA72C10 is offline   Reply With Quote
Old 06-19-2008, 09:29 AM   #7
stunna
i have a 12 bolt with a 373 ratio, anyway the wheel people are now telling me they can't get me a 10 inch wheel unless i run a 5 on4.5 bolt pattern now. i'm not sure if i want to do that i may just go with the 5 on 5 pattern that i have and get a 9.5 inch wheel.
