powder coat guys
called a local powder coat place, i asked if i could use body filler to fix a few small dings in my 72 grill and then get it coated in "almost Chrome" have any of you ever done this? will you be able to see where i fixed? how coarse of a sandpaper scratch will powder coat fill in..
thanks if you have pics ofa powdercoated grill id like to see it |
Re: powder coat guys
good question, as i have often wondered this same thing...
you cant use regular body putty but you can use something like evercoats "metal to metal" filler or some guys use"allmetal"//eastwood carries both
scratchets?depends how thick the powder is laid down and weather the coater does single or multi coats //on some of my show bikes i've had them coat it thick then i've wetsanded and had them second coat for the finished product// i've had no problems over 80grit paper marks but gotten alot more perfect results with 500sanding
No bondo.With powdercoat,think magnetic and you`ll be fine.
yup, can only pc metal surfaces
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
I wonder if JB weld would work? It's metalic right? I think its even temperature resistant up to 500 degrees.
When I coat stuff, I let it flow out at 450, so your filler also has to be able to withstand that. |
im gonna dissagree with most of what is said......the "think magnetic" made me think, we powder coat (actually farmout) lots of aluminum parts for aircraft, and alumnium isnt magnetic....then i did some good ol googleing and found that they can PC most any surface, such as glass, bone, and wood just to name a few.......so im thinkin a filler like "all metal" would work...???
special-k :this isnt dirrected at you, just passing along some info for everyone ![]() |
Not to be a jerk 68 short step. You can't powder coat glass or bone or wood, the reason being is that you use an electrical charge to get the Powder to stick to the metal. I use to be a metal prep. tech. ( Fancy Title HUH) jk. And we did have to use a special metal to metal filler for Powder Coating.
any body got any pics?
#10 | |
Sierra Grande Club
![]() I get a powder coat magazine for shops that do powder coating that highlights all the new stuff that they do. I'll get a link and post it up. http://www.metalfinishing.com/index.html I haven’t tried searching this site, but they have very informative articles on new technologies in powder coating. I’m sure they can be found on their site. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 06-19-2008 at 08:26 AM. |
I'll throw in a bit here...
I'm pretty sure anything that can withstand the flow-out temp can be coated. You Just need the electrical charge to draw the powder to the part so you get good coverage. I've coated small parts such as bolts and such, and have used a drilled block of wood to hold them while coating and baking. The powder sits on the wood and flows out just as it would on anything else. So I know you can coat wood, but coverage can be strange without the electrical charging. Anyway seems like bondo would shrink up under that kind of heat anyway.
-- Shawn '67 Short Step '70 Short Wide |
I have used JB weld before with good results the powder does stick to it. Here is a company I use for supplies and this is their metall filler page:
http://store.columbiacoatings.com/cg...P&keywords=all
Alex 1971 Lil' Red 350 SBC 700R4 |
#13 |
#14 |
Wow you learn somthing new every day. Crazy..This is why I love this site.
#15 |
Old Skool Club
![]() Join Date: Jun 2001
I asked about getting my grille powder coated. I was told that the near-chrome stuff, just wasn't quite right for the look I wanted. So, he suggested a trip to Sherwin-Williams automotive paint store to pick up a Wheel Polishing Kit.
Basically, you have to sand out as many of the surface imperfections as possible, then start polishing the aluminum. Eastwook sells some stuff that is designed to remove the anodizing, but I've read on here that Oven Cleaner will, too. I have not started on my grille yet, but it's gonna happen. Seems like Zoop's has a sealer of some sort that is supposed to last for several years, that I will try out. It was my desire to NOT pay for a new grille that lead to this decision. Having a restorer to work on it would have been just as expensive, too.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#16 | |
~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 1970 Custom/10 LWB-Stock and ugly, for now. 2005 Custom Chopper-100ci Rigid. 2004 Dodge Ram...did he say "Dodge"... |
