Old 06-18-2008, 07:18 PM   #1
jdfrmnt
Question disc swap ?
i read soom where that you can use 3/4 ton lower control arms off a 67-72 truck and 98 or newer spindle to get discs has any one done this and if so any problems i would like to know these thing befor i start thanks for the info
jdfrmnt is offline   Reply With Quote
Old 06-19-2008, 03:11 AM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: disc swap ?
I have , but have yet to get it to the alignment shop . Here's a link . http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 06-19-2008, 09:40 PM   #3
jdfrmnt
Re: disc swap ?
thanks for the reply did you have to cut the tie rods or did they fit 1st time out or any other probs did you incounter you see my big problem is my truck is my dd so down time is big time thanks
Old 06-20-2008, 09:59 PM   #4
bdydrp97s10
bdydrp97s10's Avatar
Re: disc swap ?
ive heard you can do this but swapping the whole front crossmember from a 73-87 truck would be alot easier.. it all hust bolts to the frame.. no mis matched parts.. and you can ussually score the whole crossmember for about $100-150
bdydrp97s10 is offline   Reply With Quote
Old 06-20-2008, 10:56 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: disc swap ?
I was going to do this method but never hooked up with a good set of 3/4 ton lower arms. From everything I have read, you can use '67-'81, just anything '73 and up uses rubber bushings.
Once you have the lower arms, you use the '88-'98 light duty 3/4 ton spindles, rotors and calipers (or '92-'98 1/2 ton spindles, same spindles). Just use the ball joints for those years.
Nice thing with this is, you can use either 5 or 6 lug rotors and if you ever wanted to change to the other one, just buy that rotor and you're done. Everything else is the same.
As for the tie rods, that above post does talk about which ones to use. That was the only unclear part but it did seem the right part numbers were finally figured out.
If you need a set of spindles, I have some I am not going to use, since I picked up a full disc setup from a '74, PM me.
Good luck.
chevy_mike is offline   Reply With Quote
