06-19-2008, 12:11 AM | #1 |
Speedometer Problem
Hi Guys,
I have a 72 Chev Fleetside. Speedo cable replaced today but not reading correctly. I realize tire size can throw this off but not by 30-40 mph. When I am doing 60mph it registers about 100 mph on the gauge. Ever hear of this or know of a fix for it? Thanks |
06-19-2008, 05:16 AM | #2 |
Re: Speedometer Problem
It is possible that the speedometer itself is causing the problem but I would suggest checking the speedometer gears in the transmission first.
If the rear end gear ratio has been changed the speedometer reading can be affected substantially. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
06-19-2008, 09:34 AM | #3 | |
Active Member
When I converted my 69 from a 6 to a v-8 it threw my speed off by a bunch. I think the rear axle used to be a 4.11. Later I swapped it for a 3:08 and it sure helped. If you throw in overized wheels or tires you can see where that may really mess you up. |
06-19-2008, 10:54 AM | #4 |
The Older Generation
Like the other guys said, trans change, rear end change, tire change can all affect it. If the spedo is working I would say you just need to change the speedo gears in the tranny. Here are a couple of web sites that may help. http://www.bgsoflex.com/speedo1.html http://www.transmissioncenter.net/sp...n_______va.htm LockDoc
