Removing Wipers To Install the Cowl
I have a 1970 chevrolet c20 custom camper truck. I am trying to remove the wipers on this truck to install the cowl.
Appreciate your guidance on how to remove the wipers. THANKS |
Re: Removing Wipers To Install the Cowl
take a screwdriver and a rag, place the rag on the cowl. Then take the screwdriver and wedge it behind the arm. There is a little piece of metal that slides into a grove on the shaft. Once you wedge the screwdriver under the arm(on the metal clip) just gently pull up and they should slide off.
Rottenwood Garage Member
Above is correct.......there is a small tab under there that holds it on......put a pocket screw driver under the tab and then pry it off with your big driver and the rag to protect the paint
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
Active Member
![]() Join Date: Jul 2007
After you protect the cowl -as berencam mentioned- you may have to lift the arm up before you can lift them out. I've heard some had a locking clip that prevents them from being lifted out unless you raise the arm.
Also, these old truck are around 40 years old and the arm may be hard to remove at first. You may have to wiggle and pry at the same time. I had to use a pry bar on mine the first time I did it. Also, on mine at least, they didn't have a lock on them just a spring load clip that fit in the groove. |
![]() Join Date: Jan 2007
I did mine a bit different - but the principle is the same...
I went to get mine off and the tabs were gone...so I took a towel, a block of wood and a pry bar. I laid the towel down on the cowl, then put the block of wood on top of that a bit away from the wiper arm for leverage, then placing the pry bar under the wiper arm and on top of the block of wood and pushed down on the free end. it makes sense once you do set it up...I have done this on 3 different trucks now without issue (but be careful not to damage the linkage, arms, etc. when you do this). Also note the position of the wiper arms when they are removed - since there is no markings on the linkage to show where they were attached. Last edited by lks dcvn; 06-19-2008 at 11:54 AM. |
Old Skool Club
![]() Join Date: Jun 2001
There is a tool.
I bought mine from NAPA. It fits underneath the wiper arm at the post, and then you squeeze the handles. It lifts the hinged base from the post. Piece of cake.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Firefighter
^^^^What ChevLoRay said!!!! The tool works great and there is no danger of scratching the cowl!!!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Nothing to see here.....
![]() Join Date: Jun 2007
I'm in too. anyone have the NAPA part#, pretty pleeeez??
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
Junior Member
I took them off my '67 as described today with a little extra effort because of rust.
A special tool sure would come in handy since my son and I do so much work on these old trucks. Danny |
You can also use a curved pic. You can get a cheap set at Big Lots or Home Depot has them. Just hook the clip and pull up. They also work great at removing window cranks. Just slide it between the door panel and crank and hook the clip and pull it out.
Also it does take a little coercing because as stated earlier they are 40 years old and the spring that helps apply it to the windshield also binds it to the shaft. So you are fighting it all the way off.
