Senior Moment
![]() Join Date: Mar 2002
Ouch it Broke
Father’s day my son and I went to a car show. On the way home I opened up the electric cut outs on the headers and let her rip down the freeway, LOTS OF NOISE AND FUN. Anyway as we come off the freeway ramp I said to my son "see when it gets warm you can hear that damn lifter ticking" (Typical Big Block) than all of a sudden it got a whole lot louder. Oh Sh!t I said I think we broke some thing, as it dropped a cylinder. Managed to get it home and pulled the valve cover, hey where’s the push rod? oh here it is way down in the hole. I pulled the push rod out then said "hey where’s the lifter?
I pulled the intake and there it was lying in the valley. Long story short it killed the cam, those good hard push rods I bought took did a fine job of dinging up the lobe. This motor always sounded like solid lifters even though it is hydraulic so I said “well if it wants to sound like solids then solid shall be”. I ordered a Lunati 20202: it’s the 396/427 HiPerf cam that came in the 69/70 SS Chevelle’s. I'll let you know how it all works out when I get it in. Cam should be here early next week
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Old Skool Club
![]() Join Date: Jun 2001
Re: Ouch it Broke
I grew up with the "if you can't make it run, make it loud" philosophy drilled into my head. So, my truck is loud.
Sounds like yours got too loud and then quit, huh? Is there a moral in this story? Geeze, wish I had a big block.... Let us know how it turns out. I'm jealous.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 06-19-2008 at 12:25 PM. |
1975 C-10 Silverado LWB
Re: Ouch it Broke
I have a quick question, what cut-outs do you use?
1975 LWB C-10 Silverado - Stock - "BIG 10" - 4 Bolt 350 "Brand new" 1200mi - THM-375 "Brand new w/trans cooler" 5000mi 1995 Ford Lightning - Bone Stock - 351W - Vortech?? |
Re: Ouch it Broke
i'm surprized the 350 stays in one piece behind the big block
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
![]() Join Date: Apr 2008
Re: Ouch it Broke
Just go ahead and put a roller cam in it,and some heads and while your at it bump the compression a bit.hmmm maybe a stroker crank.Sorry its an illness I cant help it.
Re: Ouch it Broke
put a diesel in it
1970 k20 350 4speed hd44 14b Circumventing the language filter is against site rules |
Happy Camper
Re: Ouch it Broke
As Tim the tool man would say... OOOHHH OOOHHH OOOHHH
RIP El Jay! Love you brother! Last edited by Jerry Jones; 06-20-2008 at 01:05 AM. |
Re: Ouch it Broke
I just subscribed to this. I want to hear how that cam works out. I just picked up a set of 71 LS6 454 Heads I plan on bolting on the 396 short block I have. Along with the 750 Demon that came with the heads. I just cant decide on the cam. I will be curious to see how you like it in yours. Take a video of how it sounds with the new cam post on You Tube and send us a link. I cant wait to hear it!
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build Last edited by Sinisterspeed; 06-20-2008 at 01:30 AM. |
Chevy nut
Re: Ouch it Broke
There is nothing like the sound of a Big Bock Chevy! That deep rumble puts the fear in the hearts of all! The excitement of opening that hood and the space is filled. Those huge valve covers...let you know this isnt what you want to play with! It will spank a small block and make it run home crying....small block FORD that is!!!
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
Official Site Guitar Shredder
Re: Ouch it Broke
lol....................
On the road
![]() ![]() Join Date: Jan 2004
Re: Ouch it Broke
I've run the factory version of that cam and also the crane copy of it several times and loved it. It will really wake it up and extend your rpm range. You may know all this but I'll pass it on in case. The only problem is you have to carefully adjust the valves and you will have to do it often and you really need to do it with the engine hot. Use a set of poly locks and you won't have to adjust it as often. Be sure to readjust it after you break it in. I always would do one side at a time, after the first side was done I would crank it and let it warm up again then do the other side. I also used a remote starter button so I could bump the engine over with less hassle while adjusting it. If you use a set of poly lock remove the studs and carefully take a file or put them in a lathe and flatten the top off so the set screw will have a flat surface to bite to.
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
Tot Roddin'
Re: Ouch it Broke
Ouch sorry to hear about that... but at least you took it for one last ride!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#13 |
Active Member
![]() Join Date: Jul 2007
Re: Ouch it Broke
Bad luck! But at least you found out what was making that ticking sound.
#14 |
Born Psycho
![]() Join Date: Feb 2001
sorry to hear that, Steve. best of luck with the new goodies, i'm sure it'll work out for the best.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#15 |
Senior Moment
Re: Ouch it Broke
These were given to me, I dont think I would pay the price otherwise
Race Ready Performance Electric Exhaust Cutout Kits Eliminate Bolting and Unbolting Your Exhaust at the Race Track Available for 2.5", 3", 3.5", 4", or 5'' single or dual exhaust, go from open to closed to anywhere in between with the flip of a switch. Race Ready Performance Kits include cutout valve(s), wiring harness, and hardware. JEGS EZ Complete Kits additionally include cutouts. Cutout Valve Features 6061-T6 billet aluminum housing machined down to .600" CNC-machined housing ensures positive seal to Y-pipe Extra thick gasket seals better and protects against heat High-temperature O-ring strengthens seal Built-in thermal protection device helps prevent motor overload Bull nose butterfly secures matching Bull nose seat Double-sealed 303 stainless steel butterfly = no leaks Stainless steel shafts, coupler, and hardware Proven, dependable gear reduction drive motor Slotted bolt holes for mounting flexibility Harness Features Weather-tight connectors Built-in, quick-blow 3 amp fuse Heavy-duty, heat-resistant 16-gauge wire Positive and negative leads labeled for easy installation JEGS EZ Complete Kits are designed by JEGS professionals so you get all the parts you need. For 2.5", 3", or 3.5" dual exhaust, each kit includes: Cutout Valves Wiring Harness Exhaust Cutouts Hardware Outlet Tips (Included on kit P/N's ending with ''1'')
#16 | |
Senior Moment
Re: Ouch it Broke
#17 |
Senior Moment
Re: Ouch it Broke
The guy who built it guarantees its and I do abuse it, so far so good
#18 |
Senior Moment
Re: Ouch it Broke
