Old 06-19-2008, 01:05 PM   #1
matt_field
matt_field's Avatar
70 4X4 swb disk front end swap, brake lines?
hey guys, on my 70 swb 4x4 i have i swapped in a front axle from a later 70s truck with disks. i then put a 71-71 master cylinder,booster,prop valve on it. what can i do for brake lines as they are different?, can i just splice in and flare them in? or get lines for a 71-72 4x4 from inline tube. thanks!!
Matt
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 06-23-2008, 08:36 AM   #2
scott123
Re: 70 4X4 swb disk front end swap, brake lines?
i ran the same line when i just did this same thing.. i used brass adaptors at the the frame to attach the flex hose...it was aggravating at first but it eventually worked out.. i bought flw/rubber lines to match the calipers and then adaptors to mate the flex line to the trucks hard line...scott
scott123 is offline   Reply With Quote
