Old 06-19-2008, 05:23 PM   #1
Houston54
Seat Option for AD Trucks
For those of us with ADs who choose to replace the seat with something else for better access, comfort or looks I have found a new option you may want to consider.
I found this seat at a local salvage yard. It is from a late model (1995) GMC Safari SLT. The seat has integrated belts, arm rests and a fold down center console. The width side to side is 54 inches and the drivers position is centered behind the steering wheel.
I had to take 4 inches off the riser and weld on a mounting flange of 3/16 plate. The rear mounting holes lined up perfectly with the rear cab supports so I only have to reinforce the front bolts.
If you are looking for a seat you might keep your eyes open for one of these. There was one other seat there in the yard if any Houston area members need one. Drop me a line and I will give you the info.
Last edited by Houston54; 06-23-2008 at 09:42 AM. Reason: Added model year of donor
Houston54 is offline   Reply With Quote
Old 06-19-2008, 07:02 PM   #2
GRIMSS
GRIMSS's Avatar
Re: Seat Option for AD Trucks
Nice find. there should be a ton of these around.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 06-19-2008, 09:28 PM   #3
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Nice find, what's the length from the floor to the bottom of the headrest, I'm thinking those would work in the 55 big window.
Tri5
Tri5Nerd is offline   Reply With Quote
Old 08-10-2008, 05:37 PM   #4
entourageguy
Yellow truck club
entourageguy's Avatar
Did we ever get a measurment on this?
Anyone else find a good combo for the 55-59 trucks?
I'm looking around for an 88-95 full size to put in so I could take an extra kid with me...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 08-11-2008, 01:31 AM   #5
Tri5Nerd
Tri5Nerd's Avatar
I think those were the rear seats from the GMC Safari, I went to the yard and found them to be rear seats. I'm still looking for something that will fit the 55-59 big window that has intergrated beats. I was told to look at the late model Chryster Sebring convertable seats. They are low enough and have the beats built in.
Tri5
Old 08-11-2008, 06:00 AM   #6
pugs
pugs's Avatar
Im using one from an 89 chevy truck, did cut down the moun like 3" but width is perfect
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 08-11-2008, 07:15 AM   #7
entourageguy
Yellow truck club
Does that seat have the fold down arm rest for the driver?
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 08-11-2008, 07:21 PM   #8
Atomsplitter
Atomsplitter's Avatar
Try looking at Chevy Tahoe's and similar, I had seen a few at the Barrie Auto Flea Market with the integrated seat belts.
Atomsplitter is offline   Reply With Quote
Old 08-12-2008, 09:43 AM   #9
Houston54
I am not able to provide the requested dimension as I have already modified the seat to fit my application. I would think this seat would not be wide enough for a task force truck. I am planning to use a middle row seat from a 99 Suburban for my 58. The only draw back to that is it does not mount on tracks but being tall this is not a problem.
The seat shown is the third row seat from the Safari van. The middle row seat does not have the integrated seat belts on both sides.
After using the seat for over 1,000 miles I am happy with it. Sure beat paying big bucks to rebuild an original or other donor.
Old 08-12-2008, 12:15 PM   #10
entourageguy
Yellow truck club
Does 3rd row seat you used have slides?
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 08-12-2008, 06:18 PM   #11
Houston54
Yes it does. I am not sure if the middle row seat assembly from the Safari/Astro vans have the tracks but the rear seat assembly does.
Old 08-13-2008, 11:23 PM   #12
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
I found a Cad. Escalade 2nd row seat for mine.
http://good-times.webshots.com/photo...99708909vsKOGt
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 08-13-2008, 11:58 PM   #13
entourageguy
Yellow truck club
Have you got any dimensions on that seat? It look nice. What kind of $$ did you have to pay for it?
Do both sides fold forward? What type of mounting is on the bottom?
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 08-14-2008, 07:37 AM   #14
BIG CHEVY 3600
Thumbs up Re: Seat Option for AD Trucks
It is a tight fit for my AD but will work out. Both seat backs fold forward and it attaches with 4 bolts to the floorboard. You can find a bunch of 2nd row GM products (Suburban, Yukon, Escalade) on Ebay. I paid $300 but nothing for freight as the seller was here in Dallas.
Abraham Lincoln
