did chevy use a split drive shaft in a 75 half ton v8? I have one in one I just picked up, never remember seeing one in a 70s or newer truck. Wayne
Gentleman Jim Driver
Well, my 1975 Gentleman Jim 350 / Th350 has one.
I'm pretty sure they were common in the long beds. |
alot of them do, mostly heavy halfs and only 3/4 and 1 tons did, ive had quite a few 73-81's with two piecers including but not limited to:
76 GMC 1500 th350 350 81 3/4 ton 2wd 350 4 speed 74 3/4 ton 454 th400 76 3/4 ton 454 th350 had a 78 Big10 th350 350 that had more GVW than a regular 1/23 ton and it only had a 72" one piecer in it. vans used two piecers even though most vans had short wheelbase. and, also 67-72 didnt only use two piece shafts, alot of them had one piecers its the drivetrain and series of truck that determined what driveshaft style it got, not the year |
Add:
81 1/2ton 2wd 4spd to the 2-piece list. Ken |
Overworked and Underlaid
my 1974 Chevy C10 LWB has one.Its a 350/TH350 equipped truck
I'd rather push a Chevy than drive a Ford The Beast-1978 C10 LWB Red-1978 C10 LWB (Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012 Gone but will never be forgotten-RIP (Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012 Taken from us to soon but you will live on in our hearts-RIP |
I've got one on my 73 3/4 ton....why did they do that?
Kelly C. Hanna MMCC & Southern Bowties Club Hanna Woodworks Classic Chevy Country |
I thought it was a deal with length. When a driveshaft gets to be longer than a certain length, they make it a two piece with a carrier beaing.
Having said that, when I took out my 1/2 ton rear end and installed a 1 ton rearend I upgraded to a 3.5" thick wall 1350 driveshaft. Mind you, this is on a longbed pickup. Some of the local driveshaft shops told me it would be too long to have a 1 piece and that it needed to be the carrier bearing design, but it's worked great.
http://home.houston.rr.com/chevy73/ |
83 C10 sm465 with 2 piece
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
