Old 06-19-2008, 07:14 PM   #1
rotgg
a/c cycling when engin rpm are up
i just put a new comp on and charged ac it is blowing cold and gages read correct but ac is cycling more than normal when rpm comes up it doesn't do it at idle i put 6oz of oil in and about 2.5-3lbs of 134a the truck is 87 r20 i did read somewhere that it took 10oz of oil but my friend wouldn't let me put that much in lol any help would be appreciated
rotgg is offline   Reply With Quote
Old 06-19-2008, 10:08 PM   #2
rotgg
Re: a/c cycling when engin rpm are up
i drove it tonight and it was cycling at idle but not as frequent as when rpms are up this is with ac on max
Old 06-20-2008, 10:35 PM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Usually when they quick cycle they are low on refrigerant, just what I've always heard.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 06-21-2008, 10:41 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
R-134 systems are finicky when operating. The fact that you are retrofitting is giving you a system that is not engineered to a set amount of freon. This means that you will have to PLAY with it. TOO much and the interior coil will frost over (this will be noted when the air flow in the cab reduces as you are driving down the road) whe you turn the A/C off for a shor tperiod and then back on, air flow returns, the coil has defrosted. The short cycling is due to a low freon charge and the pressure switch is switching the clutch on and off when the pressure increases or decreases below it's setting. The amount of R-12 in your old system will be abut twice the R-134 you will need in the same size system. You may have to let it all out and start over to know what you have.
piecesparts is offline   Reply With Quote
