Old 06-19-2008, 09:29 PM   #1
Painter D
Painter D's Avatar
alternator getting very hot. (normal?)
I replaced my alt. from Auto Zone with another Auto Zone alt. (under warranty) and the new one is charging good but gets extremely hot. So hot you cant touch it at all. Is this normal? It's a 1 wire internally regulated alt. Any help would be great.
Painter D is offline   Reply With Quote
Old 06-19-2008, 09:54 PM   #2
truckdude239
truckdude239's Avatar
Re: alternator getting very hot. (normal?)
no mine gets warm but not burning hot its messed up in side take ti back for another one. but mine is a stock alt 1 wire on back and 2 in the side for the reg
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-19-2008, 09:58 PM   #3
jdfrmnt
the alt only gets hot at hi output so ti could be to much amp draw or bad diods if you have a amp meter it will tell you witch is witch
jdfrmnt is offline   Reply With Quote
Old 06-19-2008, 10:05 PM   #4
leddzepp
Moderator
leddzepp's Avatar
The problem is you bought it at Autozone. They sell nothing but JUNK when it comes to alternators and starters. What good is a lifetime warranty if you have to keep swapping it out?? Take it to a local shop that rebuilds them in-house. I did this with mine 3 years ago and have never had a problem since.
leddzepp is offline   Reply With Quote
Old 06-19-2008, 10:21 PM   #5
Painter D
Painter D's Avatar
I'm definately taking it back ,again. If I have too much draw on amps is my only option to get a high amp alt. ? I do have alot of extras drawing power elec. fan , halogen headlamps, air compressor , plus all the other normal stuff and the alt. is a 60 amp. I dont think I mentioned above, it had a light burning smell also.
Old 06-20-2008, 09:30 AM   #6
68gmsee
Active Member
68gmsee's Avatar
Check the bearings to make sure they turn freely. Shouldn't get so hot that it burns your hand. And as mentioned the draw on the current.
The good thing about Auto Zone and other local parts stores is that they can test it and exchange it right there if it's bad. I've had to take stuff back but not that frequently.
Be aware that local shops are good but you have to wait for the repair. I had a local alternator/starter repair shop do one of mine some years ago and had to return it for repairs. No problem, but it took another 2 days before they could get it back to me.
68gmsee is offline   Reply With Quote
Old 06-20-2008, 10:55 AM   #7
70GMCer
70GMCer's Avatar
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-20-2008, 12:30 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
here is what I would do.
http://www.chevelles.com/techref/tecref14.html
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
