Old 11-09-2002, 12:56 AM   #1
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
Throttle Linkage Issues
Ok this problem came up in the last couple days and its annoying the hell out of me.When i go to start my truck in the morning and i go to pump the pedal before the truck is started i almost have to stand up on it to get the pedal to move(i didnt or anything dont worry just using that description for emphasis)but if i push the bottom part of the pedal-the end that is closest to the floor it moves fine and once it fires up and is warm the pedal moves fine.if i just push the pedal it has a spot where there is a moment of hesitation then it takes off.if i push it hard the thing stalls out.today after work i go to leave i get in and push the pedal once and it wont start like its flooded or something.let it sit for a few minutes then it starts fine.i think there is something wrong with the linkage or maybe the throttle return springs.i think maybe the linkage is worn out if thats possible or the return springs are weak and causing the throttle to stick open and flood the motor.maybe im wrong but im not the most mechanically inclined person in some areas and just want my truck running good thats all.any tips or help would be well appreciated.thanks guys
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
Old 11-09-2002, 01:33 AM   #2
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Have you made sure that your throttle linkage/bracket is not contacting the bottom of the air cleaner housing?? Mine was doing that and I just went and bought a riser for it ....problem solved.
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 11-09-2002, 02:19 AM   #3
1974ChevyC10
it actually does it with the air cleaner on or off im sure of that but like i said im not super mechanic or anything and ive been wrong before so ill check that tomorrow when its daylight.
Red-1978 C10 LWB
