Old 06-20-2008, 07:49 AM   #1
mhicks
mhicks's Avatar
Sticky Wheel
Does anybody know how to stop these old steering wheels from being sticky? I have tried many cleansers and no luck.
mhicks is offline   Reply With Quote
Old 06-20-2008, 11:19 AM   #2
seanconnery
Re: Sticky Wheel
Mine way really sticky too. I took off the faux leather wrap looking thingy cause I'd rather have just the stock steering wheel. Thats where my stickiness came from. Anyways, I used some of that "GOO GONE" stuff. It comes in a clear spray bottle and its orange scented. Its not the GOOF OFF stuff (thats solvent based I think.). I sprayed that on the wheel and slid it around with my finger and let it sit for a few minutes. Then I started wiping it off with paper towels and shop rags. The shop rags worked better cause you could really dig hard at the wheel without tearing the rag. It took several coats of this to get the stick off, and a little of it is still there.
G to the M to the C......fool!
RIP Jerry Reed "The Snowman"
seanconnery is offline   Reply With Quote
Old 06-20-2008, 01:45 PM   #3
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: Sticky Wheel
goo gone stuff really works well, that of bust out a hot HOT towel and soapy water..
but im too lazy to do that...
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 06-20-2008, 03:20 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Sticky Wheel
Wipe on cow snot and the sticky instantly goes to shiney and slick. Otherwise never had much problem there.
I seal my leather covered and plastic covered wheel with a solution that I purchase at the Tandy Leather company. It is called "Ultrasheen" and it seals the nasty out.
piecesparts is offline   Reply With Quote
Old 06-20-2008, 08:58 PM   #5
ron350
ron350's Avatar
Re: Sticky Wheel
My 75 C10 stock rubber steering wheel gets sticky when the weather changes.
When the humidity and temp are just right the sticky stuff comes out of the rubber.
I tried several chemicals and found that 91% isopropyl alcohol removed the sticky.
The next time I will try using Goo-gone and see how well that works.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 06-20-2008, 09:45 PM   #6
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
Re: Sticky Wheel
Lighter fluid, like in zippo not BBQ. The fluid breaks down the sticky but does not attack the plastic. Goo-gone can attack some plastics. I've used it on clear plastic and it didn't haze it at all.
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
Old 06-20-2008, 10:06 PM   #7
dammitmitchell
the pollock
Re: Sticky Wheel
i dont reccomend alcohol on plastics it's a bit too agressive and hazes
reallly hot water and a hot towel like u see in old barbershop shavings
also!
a cheater way to get grease off stuff is barbosol (or just old school foam in a can) shaving cream, works the residue on smokers dashboards.... .. .
seriously it does!
stop laughing at me...
Army vet 02-08
Old 06-20-2008, 10:26 PM   #8
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: Sticky Wheel
Dont eat cotton candy driving down the road. I use glass cleaner with ammonia, takes the sticky right away. Like Ron350 said, the sticky comes out of the rubber due to age. The compounds used to make the wheel are just breaking down.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 06-20-2008, 10:59 PM   #9
piecesparts
Re: Sticky Wheel
I know this sounds pricey but a good leather wrapped wheel is the "Cat's meow" and they stand up quite well to daily use. There is one on my DD with 250,000 miles on it and there is also one on my GMC SWB show truck. I bought mine through "Yogi's" and got a good price on them.
Old 06-20-2008, 11:04 PM   #10
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: Sticky Wheel
A shot of carb cleaner then a wipe over with Simple Green has always worked for me.
DirtyLarry is offline   Reply With Quote
Old 06-21-2008, 04:35 PM   #11
SCOTI
SCOTI's Avatar
Re: Sticky Wheel
I've tried several chemicals w/minimal results (after first cleaning w/some simple-green & hot water). I had some PPG urethane reducer in the garage & tried it. It removes the 'sticky' w/o removing the color/dye.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-23-2008, 10:08 AM   #12
jchav62
1962 C-10
jchav62's Avatar
Re: Sticky Wheel
I used rubbing alcohol and soapy water and a lot of elbow grease. It worked, but it sounds like there are plenty of easier way to do it...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
