Old 06-20-2008, 12:20 PM   #1
Googenheimer
Oil filter. Larger capacity?
I've recently found out that my '67 LWB has a 350 motor in it. I still don't know what from though. I think that it is from a car though and not a truck. I was trying to buy an oil filter for it last night and found out that there are basically two filters for most chevy 350s. I bought both just in case. The one that was specified for most of the 350s that came on trucks didn't fit, but the one that was specified for most of the cars with 350s DID fit. So I'm guessing the donor was a car and not a truck. (this could be totally incorrect thinking by the way) My only worry is that it is so small. All of the car type filters were really small. I would really like something that has a little larger capacity. The one I bought was the AC Delco PF454. Anybody know of a compatible oil filter that has a larger capacity and surface area?
Googenheimer is offline   Reply With Quote
Old 06-20-2008, 12:35 PM   #2
rambler
MOVE OVER
rambler's Avatar
Re: Oil filter. Larger capacity?
my 93 surburban uses that same filter as a 4x4, so still could be a truck engine, my guess is pull the block numbers off the truck. but the smaller filter was necessary for access. I think these two will work.
Carquest # 84099 Fram PH8873. (but dont recommend the fram) looks like a wix 57099 should fit
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 06-20-2008, 02:02 PM   #3
cdowns
cdowns's Avatar
readily available are remote filter assys where you can use 1or2 large filters for increased filter capacity
Old 06-20-2008, 04:37 PM   #4
1bagged67
You can use Wix Part # 51061 1qt. or a 51794 2qt. filter if you have the room.
1bagged67 is offline   Reply With Quote
Old 06-20-2008, 04:44 PM   #5
exmonkeypunk
Barrito Loco Diablo
exmonkeypunk's Avatar
You can use the shorter filter or the longer filter. The difference will be an extra 1/4 or 1/2 quart of oil and maybe a little oil pressure difference.
Most vehicles have shorter and longer filters that'll work the same.
I use a longer 4.3L blazer filter on my 3.1 malibu. I just think that "Maybe" there's slightly better filtering on a larger filter.
exmonkeypunk is offline   Reply With Quote
