Old 06-20-2008, 10:05 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
brake hose question... C/20 to C/10
I am in the middle of converting my 3/4 ton burb to a 1/2 ton burb... The brake hoses on both 72 burb front ends were toast. One set was swollen like mad, the other set was dry rotted and cracked... looked like the dirt in a dried up pond.
Went to my NAPA guy who hardly ever got me the wrong part... at least, untill I got this truck. He gets the wrong part for the burb just about every time... gettin real old, real quick.
So he gets me $50 worth of hoses, and lo and behold... they don't fit. Too short.
Now, I went ahead and looked in my LMC catalog, and noticed the P/N for 71 and 72 hoses are NOT the same from 1/2 ton to 3/4 ton.
The Calipers are the same... the lines are the same, but the hoses are not.
Can anyone here tell me what gives?
Are 1/2 ton hoses longer?
Shorter?
Purple instead of black?
I briefly considered calling LMC, but I know my customer service call would be ignored in the order it's recieved.
Old 06-20-2008, 10:08 PM   #2
uncle
Re: brake hose question... C/20 to C/10
3/4 is longer and you can't buy them at a parts store as far as I know. Factory hoses is what I'm referring to.
uncle is offline   Reply With Quote
Old 06-20-2008, 10:29 PM   #3
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Front hoses are 13" fitting to fitting for the 1/2 ton. Front hard lines are 3/16"
I'm doing my disk conversion and I'm going with Steel Braided Lines. Andy in an earlier thread you started about brake lines (on 6/15) I said I found a Company in Cali that did steel braided brake lines for $12.00 ea. MY MISUNDERSTAND The lines are actually $30.00 each. The SB Line starts at $12.00 and then your paying for the fittings. Anyway, I still feel I got a good deal since the lines are Steel Braided/Teflon hoses with crimped ends. The Company's called Bonaco, Inc. There in Upland, California. Here's there website: www.bonacoinc.com
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 06-20-2008, 10:27 PM   #4
Longhorn Man
3/4 is longer.
Sweet. this is exactly what I needed.
Guess i need to find a vendor close to Ohio.
Old 06-20-2008, 10:34 PM   #5
myoldchevytruck
Originally Posted by Longhorn Man View Post
3/4 is longer.
Andy,
Here's a company in Ohio. If you give them a sample line, they can probably duplicate it for you. http://www.ohiohydraulics.com/Conten...eFittings.aspx
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 06-20-2008, 10:40 PM   #6
Longhorn Man
my samples are gone.
Yeah, I need whipped with the dipstick from a 69 TH400.
Old 06-20-2008, 10:45 PM   #7
myoldchevytruck
My new lines come in on Tuesday or Wednesday w/ the samples. Once I check the fit, If you want my samples, I'll be glad to send them to you.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 06-20-2008, 10:50 PM   #8
Longhorn Man
I may do that... but i gotta get this thing put together with the quickness.
Old 06-20-2008, 11:04 PM   #9
myoldchevytruck
I'll PM you when I get them back.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 06-20-2008, 11:08 PM   #10
zeusflash
zeusflash's Avatar
Try GMC Paul,he came up with a set for my wifes 72 3/4 ton Suburban.
'69 3/4 ton 427 CST Pickup
'71 CST Blazer
'72 GMC 3/4 4x4
zeusflash is offline   Reply With Quote
