Old 11-09-2002, 04:42 AM   #1
Blaze69
Blaze69's Avatar
Gear ratio and codes?
Later in the day I will be opening up the front and rear dif. to change the fluid. I have really, really never known for sure the exact gear ratios for front or back. Today is a good a day as any to finally find out. Any recommendations on how to get it done.
Ohhh... what kind of codes should I look for and exactly where should I find them?????
1969 Blazer: 350/350, 4X4, HEI, Edlebrock carb/intake, dual flowmasters, np205, 3:07's and the rest is mostly stock.
The front end disc swap is finally complete
2002 Z71 Tahoe. CAI, Flowmaster 40, Silverstars in high, low and fogs and a bunch of mods (upgrades) inside and out.
Blaze69 is offline   Reply With Quote
Old 11-09-2002, 06:22 AM   #2
gmcnorton
gmcnorton's Avatar
ratios
when you pull the covers the ring gear will be stamped with numbers.. for example....41:12.. just divide 41 by 12 = 3.42 . just divide the bigger number by the smaller number and this will give exact ratio. hope that helps, kevin
70 GMC SHORT STEP , 71 BLAZER ,72 JIMMY,72 BLAZER, JUST NEED THAT SUBURBAN NOW......WANTING MORE
gmcnorton is offline   Reply With Quote
Old 11-09-2002, 08:12 AM   #3
Blaze69
Blaze69's Avatar
Thanks, I'll be on the look out for that.
