Old 06-21-2008, 04:28 AM   #1
edpdx
New 76 with unknown mods where do I time it?
Just bought a 76 with a 350 in it. The guy I bought it from said he got it 3 years ago from the guy that rebuilt the 350. It may have a cam; but it must be fairly mild as the engine does not exhibit a strong lope. The original q-jet is replaced with a 1406 Edelbrock. There is a single plane hi-rise mani. Not sure which one yet. HEI with strong wire. It runs very strong and fast. I know there is some lost HP because the obvious hi compression should deliver more. I think the air filter- a SS triangle from Edelbrock may be suffocated to the hood.
My question is: How can I get a starting point for ignition timing? Do I just check the current timing with a Light and Tach and keep coming back there at tune-up time or is there a better way?
I was thinking a dyno could dial it in and give me the specs for ignition timing. It does not answer the question: What cam / bore size have changed to if at all during the rebuild? The dyno guy in the area is spendy and though I know it is probably worth it if they do dial it in for you, I was wondering if anyone knows of another way to find out where this 350 should be timing wise?
Thanks,
Ed
edpdx is offline   Reply With Quote
Old 06-21-2008, 05:35 AM   #2
dh81k30
Junior Member
dh81k30's Avatar
Re: New 7 with unknown mods where do I time it?
Welcome.
Try this:
http://www.67-72chevytrucks.com/vboa...d.php?t=290498
Have fun, Don
dh81k30 is offline   Reply With Quote
