Old 06-21-2008, 09:30 AM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Motor mount bolts, will these work?
I hope I'm ok here, I purchased these bolts with grade 8 washers. They are a tad long but that's the shortest they had with the flange that I wanted.
I also got some 3/8-24 with lock washers in 3/4 length for the converter to flex plate.
If something is not going to work let me know!
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 06-21-2008, 10:12 AM   #2
gregbr
Senoir Member
gregbr's Avatar
Re: Motor mount bolts, will these work?
The bolts should be fine for the mount to frame, but probably too long for the mount to engine side.
The 3/4" long converter bolts are most likely to long and will hit the converter, I think the originals are approx 1/2" long.
All can be cut off and filed of course...at the time of installation.
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
