Old 06-21-2008, 11:02 AM   #1
jorgensensc
jorgensensc's Avatar
Question for the air bag guys.
I am getting ready to install the compressor and tank for my rear air bags. It is a small compressor and a one gallon tank. The problem is I can't find anywhere to mount it under the bed area. i have a stepside bed with both a blazer tank and a hidden hitch. Inside the frame rails the tank hits the trailing arms. Outside the frame rail and it looks like the steps would hit since it i a narrow bed. Under the frame rail hangs too low. Any ideas? What did you guys do?
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 06-21-2008, 11:39 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Question for the air bag guys.
Will it fit in between the hitch? Thats where I put it on my suburban.
http://67-72chevytrucks.com/vboard/s...d.php?t=162718
http://67-72chevytrucks.com/vboard/s...d.php?t=162641
Hart_Rod is offline   Reply With Quote
Old 06-21-2008, 03:35 PM   #3
jorgensensc
THanks for the pic. Unfortunately I don't have that much room between the hitch and the tank. It appears that on mine the space in between is smaller, and their is a crossmember in the spot. if I attach it to the crossmember it puts the tank lower than the hidden hitch, almost at the same level as the bottom of the gas tank. I can't put it on top of the brace, not enough room and it would hit the floor of the bed. Thanks for the pics though. Any other ideas?
Shawn
Old 06-21-2008, 05:39 PM   #4
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
inside of the frame, up front by the t-arm x member? between the frame and the trailing arm.
don't have one to look at right now, but there might be enough room in there.
IvelDesigns is offline   Reply With Quote
Old 06-21-2008, 06:57 PM   #5
minime's 68'
I have a dumb question. Do air bags give a smoother ride. I have a 4X4 and thinking about putting them on. I would be grateful for any insite. IvelDesigns I heard that there was flooding in Des Moines. Hope you didn't get any of that nasty stuff.
minime's 68' is offline   Reply With Quote
Old 06-21-2008, 07:22 PM   #6
SCOTI
SCOTI's Avatar
Yes.
When set-up correctly, they can give a smoother ride. As one board member had stated in another thread . . .... "It's like riding on air" (that one made me chuckle a when I read it).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-21-2008, 11:13 PM   #7
Kayotic
Kayotic's Avatar
Are you willing to mount to the bottom of the bed floor. Try looking between driveshaft and trailing arm, above the E-Brake mount. I just cut the exhaust out of my 70 step and that is where the muffler was mounted.
I have a see through bed right now (I got to beat out original bed wood), I will look closer in the morning.
Kayotic is offline   Reply With Quote
Old 06-22-2008, 09:25 AM   #8
jorgensensc
Thanks for the post guys. Y'all are thinking the same areas I have been thinking. Beside the trailing arm on the frame doesn't fit, and my mufflers are in the space you were talking about by the trailing arm crossmember. I guess I will have to look at it again when I get the bed on it. I was hoping to get it all plumbed up before putting the bed back on, but It doesn't look like that is going to happen.
Shawn
Old 06-22-2008, 10:13 AM   #9
Boog
laying low
Boog's Avatar
Shawn I don't know how large the compressor is but can it be mounted outside the frame under the cab? No exhaust issue there.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-22-2008, 02:14 PM   #10
SCOTI
SCOTI's Avatar
That's where I would try & mount the tank as well.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
